Spent hours trying to get my beagleboard to work over s-video then
finally composite only to discover I can't stream the files over my
network using samba. My guess is perhaps the kernel wasn't compiled
for cifs or samba filesystems, because I keep receiving errors about
the file system when attempting to mount.
1. is this a probable cause seeing as cifs and samba are installed?
a) if so, how would I go about compiling a new uImage? I'm currently
using the demo angstrom image. Which is the only one I've found that
works well with s-video + composite at the moment.
2. What is the best way to go about mounting folders from the host
machine on the beagle.
It's probably a given but I wish someone wrote underneath the angstrom
instructions to opkg update/upgrade to get the to get alsa working. I
can only imagine how many people wasted as much time as I did trying
to fix the sound in mplayer.
I'm converting s-video to coaxial or composite. So of course
omapdsss.tvcable isn't necessary if you're just using s-video and if
you're using a pal tv change omapfb.mode=tv:pal
if you're like me and browse these discussion forums save this script.
and create-boot-scr run it with sudo sh ./create-boot-scr.sh
