Friends,
Trying to boot an imga of SitaraSDk 6.0.0 on my BeagleBoard xM
my boot partition contains
MLO, u-boot.bin, uImage
I am Getting following error in my console :
Welcome to minicom 2.5
OPTIONS: I18n
Compiled on May 2 2011, 00:39:27.
Port /dev/ttyUSB1
Press CTRL-A Z for help on special keys
Texas Instruments X-Loader 1.5.0 (Jun 14 2011 - 22:04:07)
Beagle xM
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2011.03-rc1-00000-g9a3cc57-dirty (Apr 01 2011 - 17:41:42)
OMAP36XX/37XX-GP ES2.1, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle xM Rev C
No EEPROM on expansion board
Die ID #1a9600029ff80000016849a90101f025
The user button is currently NOT pressed.
SD/MMC found on device 0
reading uEnv.txt
** Unable to read “uEnv.txt” from mmc 0:1 **
Loading file “/boot/uImage” from mmc device 0:2 (xxa2)
** File not found /boot/uImage
Booting from nand …
no devices available
Wrong Image Format for bootm command
ERROR: can’t get kernel image!
OMAP3 beagleboard.org #
Do i Have to add uenv.txt too ?
Please Give the suggestion.
