If ntpd service is running it will automatically update the time on boot so there is no need to resort to ntpdate.
/usr/sbin/ntpd is part of the ntp package.
Regards
Sid.
I have started looking at the Journal information (journalctrl), to help debug why I can not get my wifi to work… And I think the issue with the date is that it is run before the network gets up and bails. I see some time stamps like:
journalctl -b
Dec 31 16:00:02 beaglebone /usr/sbin/crond[129]: (CRON) INFO (Syslog will be used instead of sendmail.): No such fi
Dec 31 16:00:03 beaglebone avahi-daemon[131]: Found user ‘avahi’ (UID 998) and group ‘avahi’ (GID 996).
Dec 31 16:00:03 beaglebone avahi-daemon[131]: Successfully dropped root privileges.
Dec 31 16:00:03 beaglebone avahi-daemon[131]: avahi-daemon 0.6.31 starting up.
Dec 31 16:00:04 beaglebone ntpdate[207]: Can’t find host us.pool.ntp.org: Name or service not known (-2)
Dec 31 16:00:04 beaglebone ntpdate[207]: no servers can be used, exiting
Dec 31 16:00:04 beaglebone connmand[130]: Connection Manager version 1.4
Then later the network responded and setup eth0… For example finally got an address…
Dec 31 16:00:11 beaglebone avahi-daemon[131]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.2.149.
Dec 31 16:00:11 beaglebone connmand[130]: Deleting host route failed (No such process)
Dec 31 16:00:11 beaglebone avahi-daemon[131]: New relevant interface eth0.IPv4 for mDNS.
Dec 31 16:00:11 beaglebone avahi-daemon[131]: Registering new address record for 192.168.2.149 on eth0.IPv4.
Dec 31 16:00:11 beaglebone connmand[130]: eth0 {add} address 192.168.2.149/24 label eth0 family 2
Dec 31 16:00:11 beaglebone connmand[130]: eth0 {add} route 192.168.2.0 gw 0.0.0.0 scope 253
Dec 31 16:00:11 beaglebone connmand[130]: eth0 {add} route 192.168.2.1 gw 0.0.0.0 scope 253
Dec 31 16:00:11 beaglebone connmand[130]: eth0 {add} route 8.8.8.8 gw 192.168.2.1 scope 0
Dec 31 16:00:11 beaglebone connmand[130]: eth0 {add} route 0.0.0.0 gw 192.168.2.1 scope 0
Dec 31 16:00:11 beaglebone connmand[130]: Setting default gateway route failed (File exists)
The kludge I am doing, is on my root account, I updated my .bashrc file to add:
ntpdate-sync
Does not work if I wish to create another user and run it from there, but once I logon, this does finally update the date. Hopefully we will come up with a better solution as I would like to put this on a robot and hopefully not have to putty into it to set things up…
