Hello everyone.
Does anyone know how to toggle on and off the usb port on the beaglebone black? I basically need to turn off a webcam so i can save some battery. Thanks in advance.
Hello everyone.
Hi @Andres_Ulloa there is a gpio pin you can toggle, to turn off the USB bus…
I last tried it in 2015, it definitely took down the USB port… However when trying to bring it back up, the USB subsystem kernel panic’ed.
Thanks Robert, this helps.
Hi Robert,
Thanks for this. I’m also keen to be able to power-cycle USB devices from a script.
I’ve tried adding the device-tree entries like this (I’m not using overlays):
usb_power_ctl_a {
pinctrl-names = "default";
pinctrl-0 = <&usb0_pins>;
compatible = "gpio-leds";
usba {
label = "EN-5V-HDA#";
gpios = <&gpio0 18 GPIO_ACTIVE_HIGH>;
default-state = "on";
&am33xx_pinmux {
usb0_pins: usb0_pins {
pinctrl-single,pins = <
AM33XX_PADCONF(AM335X_PIN_USB0_DRVVBUS, PIN_OUTPUT, MUX_MODE7) /* usb0_drvvbus.gpio0_18 */
&usb0 {
status = "okay";
dr_mode = "host";
However, this results in the kernel complaining at boot time, and no entry is created under /sys/class/leds:
[ 2.132563] pinctrl-single 44e10800.pinmux: pin PIN135 already requested by 47401400.usb; cannot claim for usb_power_ctl_a
[ 2.132603] pinctrl-single 44e10800.pinmux: pin-135 (usb_power_ctl_a) status -22
[ 2.132620] pinctrl-single 44e10800.pinmux: could not request pin 135 (PIN135) from group usb0_pins on device pinctrl-single
[ 2.132636] leds-gpio usb_power_ctl_a: Error applying setting, reverse things back
[ 2.132666] leds-gpio: probe of usb_power_ctl_a failed with error -22
If I take the pinctrl lines out of usb0, then there are no kernel errors, and there’s an entry under /sys/class/leds/EN-5V-HDA#, but changing the “brightness” from 1 to 0 and back has no effect: devices do not enumerate and the USB bus does not work.
If instead I take out the usb_power_ctl_a
portion, the error is fxed, but there’s nothing in /sys/class/leds to toggle, obviously.
So it appears that the USB driver really wants to own the USB0_DRVVBUS
pin.
What am I missing? I’m using kernel 5.10.59-bone49.
Thanks for any advice,
–Andrew.
