u-boot creation on beagleplay
I am getting back to create a gentoo for the Beagleplay
I have created u-boot but am confused as to what u-boot is the one to use.
I I have followed the instructions and there is two u-boot, one for the R5 and the other A53
When compiling for the R5 I get u-boot.img and tiboot3.bin
and for the A53 I get u-boot.img and tispl.bin
You can see how I compile it on my gentoo wiki which you can get to on my website
https://suzielinux.com/
Hi @MichelC it’s a multi-stage with multple cores… Here is the readme, look at the Boot Flow picture: u-boot/doc/board/beagle/am62x_beagleplay.rst at master · u-boot/u-boot · GitHub
Here are the a current stable branches/tags: build_u-boot.sh · main · BeagleBoard.org / u-boot-beagleplay · GitLab
Where is the important part regarding how this is actually built?
Interesting, well i have it here… build_u-boot.sh · main · BeagleBoard.org / u-boot-beagleplay · GitLab
Cool, thank you.
Am I correct to assume defconfig for the ai-64 and am67a will work with that script?
The am67a beagley-ai will not boot with the evm u-boot + arago. Will the beagley-ai deconfig work with arago so it will boot.
Also, where is the master sysconfig file for both those boards so I can load that up into sysconfig tool and make changes.
beagley-ai isn’t on mainline u-boot yet, i need to fix that, it also use hs-fs silicon vs Plays’ gp, so some differences…
Here’s my script: build_u-boot.sh · main · BeagleY-AI / u-boot-beagley-ai · GitLab
AI64 is similar to Play https://openbeagle.org/beagleboard/u-boot-beagleboneai64/-/blob/main/build_u-boot.sh?ref_type=heads accept for the sysfw.itb
I’m not touching arago…
Will I get a surprise package with that? I have not been able to begin testing it other than the console works. Need to get i/o on the header up first, and that 10 second boot is nice.
U-Boot on K3 is a complex build…
First build trusted-firmware-a (bl31.bin) then optee for (tee-pager_v2.bin)
Build U-Boot for R5 which needs ti-linux-firmware… Which gives you tiboot3.bin (and if needed sysfw.itb)
Finally Build U-Boot for A53 which needs bl31.bin, tee-pager_v2.bin and ti-linux-firmware… Which gives you the final tispl.bin and u-boot.img
(it was even worse when we launched the bbai64, as there was special k3-image-gen repo that got moved into u-boot’s binman infrastructure…)
I was able to compile u-boot with your script after I modified it
I had to change CC64=aarch64-linux-gnu- to CC64=aarch64-unknown-linux-gnu-
because the cross compiler on gentoo has a different name
In the line to compile trusted-firmware-a I added ENABLE_PIE=0
It fails compiling on gentoo unless that is done
/usr/libexec/gcc/aarch64-unknown-linux-gnu/ld: attention: création de DT_TEXTREL dans un PIE
I am not sure what that PIE is about.
I was looking for a holder for the debug connector and found one at digikey for $18
a bit pricy. I did find a file to print one on my 3D printer. Is that thing good?
pie: position-independent executable (PIE) thinking in head… that’s loaded by u-boot when building u-boot… might not be a good thing…
Debug Connector, don’t spend more then ($12) https://www.digikey.com/en/products/detail/raspberry-pi/SC0889/17877576
At this point every board we make uses a PI standard jst now… the play still used the old 2.54mm header which the PI debugger has in the box…
The PI debug probe can be picked up almost anywhere today.
I was talking about the JTAG cable.
Tag Connect Retaining Clip
looks like they’ve removed this going forward… fix(rme): remove ENABLE_PIE restriction · TrustedFirmware-A/trusted-firmware-a@e126ed1 · GitHub
