Its not a beagle board but just regular uboot functionality I am trying to understand.
I have this uboot
VERSION = 2017
PATCHLEVEL = 03
I am trying to silent the console using the silent variable.I defined this #define CONFIG_SILENT_CONSOLE
So at boot time I am interrupting the console, and entering
setenv silent 1
save
reset
Now after reset, or power on reset I try again get console logs.After seeing env variables
printenv
I see my saved variable correctly in env varibles
silent=1
but still u-boot is not silent. I suspect this function is failing at checking for this env variable,
char *getenv(const char name)
if (gd->flags & GD_FLG_ENV_READY) { / after import into hashtable */
ENTRY e, *ep;
WATCHDOG_RESET();
e.key = name;
e.data = NULL;
hsearch_r(e, FIND, &ep, &env_htab, 0); /this function is maybe returning/
return ep ? ep->data : NULL;
/* restricted capabilities before import */
if (getenv_f(name, (char *)(gd->env_buf), sizeof(gd->env_buf)) > 0)
return (char *)(gd->env_buf);
return NULL;
But what exactly is happening?
Is there something like before relocation time env variables and after relocation env variables because the function,
static void console_update_silent(void)
#ifdef CONFIG_SILENT_CONSOLE
if (getenv(“silent”) != NULL){
puts(“silent”);
gd->flags |= GD_FLG_SILENT;
else{
puts(“Non silent”);
gd->flags &= ~GD_FLG_SILENT;
#endif
/* Called before relocation - use serial functions */
int console_init_f(void)
gd->have_console = 1;
console_update_silent();
print_pre_console_buffer(PRE_CONSOLE_FLUSHPOINT1_SERIAL);
return 0;
console_init_f says its before relocation.
I have put some prints to see and always gets non silent, even if I have saved the silent variable,
I am using a sd card to boot(mmc), I don’t have any debugger, so I
I tried printing default environment, as
env print default
Error: “default” not defined
So there is not default environment too.
Any tips or help will make me understand.
P.S.
I explicitly defined silent in #define CONFIG_EXTRA_ENV_SETTINGS
Now u-boot is silent, but I don’t see this env variable on doing printenv
Doing a setenv silent should remove this from env variable but still on reboot my uboot is silent. So something about environment variable is clearly mystery to me.
