Hello all…
I am trying to use a newer image than I have in the past:
BeagleBoard.org Debian Image 2017-10-10
I have flashed the eMMC and am able to boot from it with no microSD card in place.
I have been working for the last year with an older (2014) image and I compile and load an overlay.using the capemgr (sudo sh -c “echo DesiredOverlay > /sys/devices/platform/bone_capemgr/slots”) method. I understand from other posts that this is no longer the preferred method, and I need to use the new method. I think I have done what the following suggests:
https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
starting at: U-Boot /boot/uEnv.txt configuration
But I can’t use the same PRU processes as I used before. I get an error (Segmentation fault) that in the previous image would indicate that I had not yet loaded the overlay. I don’t see anything in the dmesg output that would indicate that the uboot/uEnv.txt had run at all.
My questions:
- Does it look like I am properly loading the overlay (EBB-PRU-CNKSim-00A0.dtbo) in the uEnv.txt?
- Shouldn’t I be able to see this in the dmesg output?
- Is there a possibility that the /boot/uEnv.txt is not being run?
- Is there an easy way to put tell-tales in the uEnv.txt file so that you could easily see where in the file the process had gotten to?
Thanks in advance,
Alan
dmesg_result.txt (23.5 KB)
uEnv.txt (2.04 KB)
