I created 2 exact partitions with the same kernel, and rootfs, which I built as per eee wiki for beaglebone black. I am currently unable to move to the second partition.
Here is my partition layout:
root@arm:/home/ubuntu# fdisk -l
Disk /dev/mmcblk0: 7.22 GiB, 7744782336 bytes, 15126528 sectors
Units: sectors of 1 * 512 = 512 bytes
Disklabel type: dos
Disk identifier: 0xfb2889fe
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 7462912 7454721 3.6G 83 Linux
/dev/mmcblk0p2 7462913 15126527 7663615 3.7G 83 Linux
Disk /dev/mmcblk1: 3.58 GiB, 3825205248 bytes, 7471104 sectors
Disklabel type: dos
Disk identifier: 0x9c2c8b97
/dev/mmcblk1p1 * 8192 7471103 7462912 3.6G 83 Linux
In the above, /dev/mmcblk0p1 and /dev/mmcblk0p2 are the ones that are created by me.
However, when I tried to move to the 2nd partition in u-boot command-line I could not : It failed with an ERROR.
=> mmc dev 0 0
switch to partitions #0, OK
mmc0 is current device
=> mmc dev 0 1
switch to partitions #1, ERROR
=> mmc list
OMAP SD/MMC: 0 (SD)
OMAP SD/MMC: 1 (eMMC)
=> mmc part
Partition Map for MMC device 0 – Partition Type: DOS
Part Start Sector Num Sectors UUID Type
1 8192 7454721 fb2889fe-01 83
2 7462913 7663615 fb2889fe-02 83
=> mmc dev 0 1
It’s important to note that I can view both partitions with ext2ls ; its just that u-boot is unable to recognise the second one.
=> ext2ls mmc 0:1 /
4096 . 4096 .. 16384 lost+found 4096 opt906035200 armhf-rootfs-ubuntu-focal.tar
4096 var 4096 bin 4096 boot 4096 dev 4096 tmp 4096 root 4096 mnt 4096 proc 4096 lib 4096 srv 4096 sbin 4096 usr 4096 sys 4096 home 4096 etc 4096 media 4096 run=> ext2ls mmc 0:2 /
4096 . 4096 .. 16384 lost+found 4096 opt 4096 var 4096 bin 4096 boot 4096 dev 4096 tmp 4096 root 4096 mnt 4096 proc 4096 lib 4096 srv 4096 sbin 4096 usr 4096 sys 4096 home 4096 etc 4096 media 4096 runU-Boot 2019.04-00002-g07d5700e21 (Mar 06 2020 - 11:24:55 -0600), Build: jenkins-github_Bootloader-Builder-137
arm-linux-gnueabihf-gcc (Linaro GCC 6.5-2018.12) 6.5.0
GNU ld (Linaro_Binutils-2018.12) 2.27.0.20161229
Let me know what I am missing
Regards
Ashutosh
