Hi all,
I am trying to build U-Boot 2019.7 for my BeagleBoneBlack so that it utilizes the HW partition on the eMMC (/dev/mmcblk1boot1) for it’s environment and also set up a redundant environment so that I can have power cut safe updates. I have the following configured:CONFIG_ENV_IS_IN_EMMC=y
CONFIG_ENV_OFFSET=0x0
CONFIG_SYS_MMC_ENV_DEV=1
CONFIG_SYS_MMC_ENV_PART=2
CONFIG_SYS_REDUNDAND_ENVIRONMENT=y
CONFIG_SYS_ENV_OFFSET_REDUND=(CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE)
With CONFIG_ENV_SIZE being 128k (0x20000), my fw_env.config looks like this:
Block device example
/dev/mmcblk1boot1 0x00000 0x20000
/dev/mmcblk1boot1 0x20000 0x20000
This works fine when compiling and what not. I can “saveenv” in u-boot and do a hexdump on the hw partition and see that my variables were stored between 0x0 and 0x20000.
However, as a user, when I use “fw_setenv x 1”, the command then re-writes my enviornment starting at 0x20000 (the second line of my fw_env.config) along with my new variable x . When rebooting and going back into u-boot, it does not see x=1 after a “printenv x” because it is loading the first environment at 0x0.
Basically, on boot, u-boot is using a different environment as the one that libubootenv is printing and setting.
Why is this the case? Does that still make my system safe for power-cut updates?
