i just got my new BeagleBoard-xM, it came with a prepared Angstrom card
that it can boot from.
I bought a new uSD card and try to install buildroot on it. It does not
work as expected, i prepared the card according to some descriptions i
found googling, first setting up the uSD cards parameters:
heads: 255
sectors: 63
cylinders: trunc(size/255/63/512)
1st partition as type 0x0C, 50 Mb
2nd partition as type 0x83, rest
I created the MSDos file system:
mkfs.msdos -F 32 -n "beagle" /dev/sdc1
Also, the 1st partition is bootable.
I use "minicom" with 1152008N1 to see the serial output of the boot process.
First i only got "60" as the only output on the serial line when i powered up
the board.
I copied "MLO" to the SD card as the first action after creating the file
system, also "u-boot.bin". Now i only get some weird character garbage
when booting up.
I'm not really sure what i do wrong. I have some questions, e.g.:
- Where should i get "MLO", i copied it from:
http://beagleboard.org/demo/esc#boot
Is this the preferred way? Do i need to compile / configure it?
I first made a backup image of the working uSD card that came with the board:
dd if=/dev/sdc of=beagle_backup.image
If i now copy this backup to my uSD card that i prepared as described above:
dd if=beagle_backup.image of=/dev/sdc
Then the board boots up fine, so i guess the uSD card is set up properly by
HW.
I created a "user.scr" by writing an input.scr text script like:
mmc init
setenv console tty0 console=ttyS2,115200n8
I created user.scr from it with:
../host/usr/bin/mkimage -A arm -O linux -T script -C none -a 0 -e 0 -n lassie
-d input.scr user.scr
I copied the files directly into the msdos filesystem that is on partition1 of
the uSD card. So the files are on the card, but the sectors are not at
defined offsets, i'm not sure if this is necessary?
It seems to me that either MLO or u-boot.bin try to write something on the
serial line, but with 115200,8N1 there is just weird garbage, also with
9600 and 38400.
Does anybody have a hint on how to set up u-boot to load an init script and
then boot a linux kernel?
Thanks for any hints,
Torsten.
