Apologies, as this is likely me . But stuck, so hoping someone has some debug thoughts / pointers. I am trying to build (compile) my own U-Boot, for BeagleBone-AI (not 64). I built (cross-compiled) as below (from stock U-Boot code) … it seems to build fine,
sudo aptinstall gcc-arm-linux-gnueabihf
export CROSS_COMPILE=arm-linux-gnueabihf-
export ARCH=arm
make distclean
make am57xx_evm_defconfig
make -j16
FYI, I did build “hello.c” as a test also … copied the output over, and it runs fine (on the bbai). So thinking cross-compiling is working?
But on U-Boot, I have tried to install it 2 ways,
Use the flasher image, but replace MLO and u-boot-dtb.img with my files. Flashes, but boot after … just hangs.
Manually flash to eMMC, the two noted files using dd commands (from install-mmcblk0.sh … the same result, And I admit, the dd commands confuse me just a bit, regarding offsets LOL
So looking for any and all pointers - thanks in advance! BTW, in case it helps, here is the file listing from cross-compiling, in case this is part of the issue (i.e. file size?). I ask this because u-boot-dtb.img is > 4x 384k blocks?
127648 Dec 14 11:56 MLO
1603724 Dec 14 11:56 u-boot-dtb.img
I’ll give that a try, NP at all - thanks! BTW, it doesn’t even start, meaning no U-Boot version number or anything displayed. Would this align with failed board detection?
Are you asking if the board died?, if none of the leds are on it is dead. We had 2 ai64 die on us and they were not in a case I cannot blame anyone other than myself for the failure. Have an ai64 production server all boxed up and its a workhorse…
If the led is on and its stuck you will have to go in on the debug port and wipe out some emmc. Use the latest flasher image to install a fresh uboot and image.
Yep, and I’m connected to the debug port - that works great . I think I know what’s going on. So the MLO and u-boot.img files that I built … I tried (with dd) writing MLO - works great. Then u-boot-img … issues. But here is what I think is going on,
using count=4 seek=1 bs=384k … the write is smaller than the u-boot.img file. So that hangs on boot. Makes sense, the full file wasn’t written, so corrupt.
using count=5 seek=1 bs=384k … yep, the write is the full file, but it shows mmc issues on boot (but does start up!)
Log from the boot (partial),
U-Boot 2024.10-dirty (Dec 17 2024 - 06:32:49 -0600)
CPU : DRA752-GP ES2.0
Model: BeagleBoard.org BeagleBone AI
Board: BeagleBone AI REV A
DRAM: 1 GiB
Core: 70 devices, 19 uclasses, devicetree: separate
MMC: no pinctrl state for default mode
omap_hsmmc_init_setup: timedout waiting for cc2!
mmc@480d1000 - probe failed: -110
OMAP SD/MMC: 0, OMAP SD/MMC: 1no pinctrl state for default mode
Loading Environment from FAT... MMC: no card present
** Bad device specification mmc 0 **
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Reading from MMC(1)... Net: eth2: ethernet@48484000
switch to partitions #0, OK
Scanning mmc 1:1...
No EFI system partition
Failed to persist EFI variables
Loading Boot0000 'mmc 1' failed
EFI boot manager: Cannot load any image
starting USB...
Bus usb@488d0000: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usb@488d0000 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
ethernet@48484000 Waiting for PHY auto negotiation to complete..... done
link up on port 0, speed 1000, full duplex
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
DHCP client bound to address 192.168.0.88 (3762 ms)
*** Warning: no boot file name; using 'C0A80058.img'
Using ethernet@48484000 device
TFTP from server 192.168.0.1; our IP address is 192.168.0.88
Filename 'C0A80058.img'.
Load address: 0x82000000
Loading: *
So it seems the larger file is part of the issue - and writing 5 blocks (384k each) causes grief? Any thoughts how to deal with that?
Sort of . By writing 5 (384k) blocks, u-boot comes up … but that write seems to mess up the eMMC partitioning? From the console log,
Scanning mmc 1:1...
So then it tries to TFTP boot … but it should boot from eMMC (i.e. mmc1). I admit, the partitioning approach is a bit confusing to me, I would have thought that 5 block write would be OK - but it seems to mess up the rest of the boot?
OK, I won’t lie - but you lost me on that one LOL. I did some searching, but I admit … not finding the partitioning info. It seems like there is a “hard” write of MLO and u-boot.img … and that extending the latter to 6 blocks (vs. the “stock” 4 blocks) somehow messes up the eMMC? But - everything I find says that 4 MB should be available there, so it’s not quite making sense. Hmmm.
OK, I think this is the key! When I update u-boot, even with a 4 block version (I rebuilt v2022.04) … it seems to mess up the eMMC, flash partitioning and/or CRC. Any way to avoid this?
Makes sense. A bit more debugging … if I replace the u-boot files (MLO, u-boot-dtb.img) on the flasher image (MicroSD) … flash and boot => I get this mmc related error message. It’s like the mmc format needs to be in u-boot somehow / somewhere, but it’s not with stock u-boot? I admit, pulling my hair out trying to figure that one out, and I don’t have enough (hair) to spare LOL.
Sorry, just saw this - my bad! . But a bit more debugging, this is very odd - and likely me, but not sure what I’m doing wrong.
If I flash MLO, the one I built - it works fine. But, my u-boot.img fails … and I think it’s somehow flashing related. I say that because if I have a working eMMC boot, but then do,
So really, just reading the u-boot that is there, to a file and flash it back. Then boot fails (hangs). Huh?!?! Am I doing something stupid? Likely . But until I get this figured out, I don’t see how my (5 sector!) u-boot.img will work.
Yep, me being stupid LOL. Needed to change seek to skip on the first one, then the file I “download” from flash looks right, and writing it back is fine, nothing broken. So the commands need to be,
But, the u-boot I build - I went back to v2022.04, so it fits in 4 blocks … still an issue. I write that file (u-boot-dtb.img) out, and it does start to boot (as below, I can see my version of u-boot!). But … still the mmc issue, so somehow the write is breaking “partitioning” (though there is only 1 partition, with fixed offsets it seems somehow!!!).
U-Boot 2022.04-dirty (Jan 07 2025 - 14:07:01 -0600)
DRAM: 1 GiB
Core: 60 devices, 16 uclasses, devicetree: separate
Scanning mmc 1:1...
Scanning disk mmc@4809c000.blk...
Disk mmc@4809c000.blk not ready
Scanning disk mmc@480b4000.blk...
Scanning disk mmc@480d1000.blk...
Disk mmc@480d1000.blk not ready
Found 2 disks
BootOrder not defined
starting USB...
USB XHCI 1.00
ethernet@48484000 Waiting for PHY auto negotiation to complete. done
link up on port 0, speed 100, full duplex
BOOTP broadcast 1
DHCP client bound to address 192.168.0.88 (4 ms)
Loading: T T T T T T T T T T T T T T T T T T T T
Retry count exceeded; starting again
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-28-ec-9a-f1-02-f0
Filename 'pxelinux.cfg/01-28-ec-9a-f1-02-f0'.
Load address: 0x80100000
Pulling my hair out . I’m not sure if it’s a DTB issue, or something else. Any pointers would be appreciated. Thanks!
OK, slight update . I did also clone and build the beagleboard.org version of u-boot (from here). I can flash and run this one, no issues. So some progress, but still odd - what is messing up the eMMC format or files? Thinking this is the key open item here.
Still trying to debug, LOL. I have been hunting around, but does anyone know how to mount the .img file (e.g. u-boot-dtb.img, output from build process)? To be able to check it in more detail.
