Hello all,
I’ve been compiling and testing various RoboticsCape example codes on the BBBlue. The distribution I currently have installed is the latest IoT image: bone-debian-9.2-iot-armhf-2017-10-10-4gb.
I have tested rc_uart_loopback on UART0, UART1, UART2, and UART5. Following the instructions in the example code, I shorted the TX and RX pins together on a breadboard and ran the program for each UART. The other three worked normally, however UART0 has been giving me problems.
On testing UART0, one of four outcomes may be encountered:
UART0 fails to initialize:
debian@beaglebone:~/bin/RoboticsCapeInstaller/Robotics_Cape_Installer/examples/rc_uart_loopback$ sudo ./rc_uart_loopback 0
testing UART bus 0
cannot set uart0 attributes
Failed to rc_uart_init0
Exiting Cleanly
UART0 times out:
testing UART bus 0
Sending 11 bytes: Hello World
timeout reached, 0 bytes readExiting Cleanly
UART0 reads back various amounts of whitespace:
testing UART bus 0
Received 11 bytes:Exiting Cleanly
UART0 works properly (occasionally):
testing UART bus 0
Received 11 bytes: Hello WorldExiting Cleanly
I used the same JST-SH-4 connector wired to the breadboard to test UART1 and UART5 and encountered no issues with those ports, so I don’t believe it’s my circuit.
The source code implies that UART0 is on a debug header. Could it be periodically in use by something in the background? Where can I find more information about the “debug header?”
rc_uart_loopback.c
This is a test to check read and write operation of UART buses.
For this example to work, connect the RX and TX wires of one of the included
4-pin JST-SH pigtails and plug into the UART1 or UART5 headers. You may also
elect to test UART0 on the debug header or UART2 on the GPS header.
The test strings this programs transmits will then loopback to the RX channel.
Robert
