Hi Tom,
I'm terribly sorry annoying you for once more time with this issue. I have
tried to figure out what patch sets you are suggesting below.
I think that at least part of the answer is that you need to enable
CONFIG_SYS_NAND_ONFI_DETECTION. You may also need to apply some of
Pekon's patches from http://patchwork.ozlabs.org/
project/uboot/list/?submitter=17320&state=* (there are 3 series there as
of this writing, 2 v2's and a v8, you should apply all 3 series, and in the
right order, saving each series to an mbox, and using git am -3 / git am
--abort when they fail should help get the right order sorted out quickly).
So, to make it clear as crystal even for me, let's list what I found
matching with your message:
2013-08-14
[U-Boot,v2,1/4] mtd: nand: omap: enable BCH ECC scheme using ELM for
generic platform
[U-Boot,v2,2/4] mtd: nand: omap: optimize chip->ecc.hwctl() for H/W ECC
schemes
[U-Boot,v2,3/4] mtd: nand: omap: optimize chip->ecc.calculate() for H/W ECC
schemes
[U-Boot,v2,4/4] mtd: nand: omap: optimized chip->ecc.correct() for H/W ECC
schemes
2013-09-06
[U-Boot,v2,1/3] am33xx: elm: add support for BCH16_ECC - ELM driver updates
[U-Boot,v2,2/3] mtd: nand: omap: add support for BCH16_ECC - NAND driver
updates
[U-Boot,v2,3/3] am335x: update README for BCH16
2013-09-30
[U-Boot,v2,1/4] mtd: nand: add NAND_BUSWIDTH_AUTO to autodetect bus width
[U-Boot,v2,2/4] am33xx: add CONFIG_SYS_NAND_DEVICE_WIDTH to determine NAND
device bus-width
[U-Boot,v2,3/4] am335x: fix GPMC config for NAND and NOR SPL boot
[U-Boot,v2,4/4] am33xx: add support for beaglebone x16 NAND cape
2013-10-10
[U-Boot,v8,1/5] mtd: nand: omap: enable BCH ECC scheme using ELM for
generic platform
[U-Boot,v8,2/5] mtd: nand: omap: optimize chip->ecc.hwctl() for H/W ECC
schemes
[U-Boot,v8,3/5] mtd: nand: omap: optimize chip->ecc.calculate() for H/W ECC
schemes
[U-Boot,v8,4/5] mtd: nand: omap: optimized chip->ecc.correct() for H/W ECC
schemes
[U-Boot,v8,5/5] board/ti/am335x/README: update for NAND boot
It seems to me that 2013-08-14 and 2013-10-10 are providing (more or less)
same patch set
=> My choice is 2013-10-10
2013-09-06 and 2013-09-30 seem different to me
=> these are the 2v2's your mentioned above
My guess for patching order would be:
1) 2013-10-10
2) 2013-09-06
3) 2013-09-30
-Matti
