uboot can't load kernel may due to uEnv.txt on BBB
Hi community:
I am trying to compile uboot and kernel from source then download them to SD card. When am3359 boot from SD card, I get the information as below.
U-Boot SPL 2019.04 (Apr 21 2025 - 20:56:18 +0800)
Trying to boot from MMC1
Loading Environment from EXT4...
** Unable to use mmc 0:1 for loading the env **
U-Boot 2019.04 (Apr 21 2025 - 20:56:18 +0800)
CPU  : AM335X-GP rev 2.0
I2C:   ready
DRAM:  512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net:   eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[t] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
16 bytes read in 10 ms (1000 Bytes/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
** Invalid partition 3 **
** Invalid partition 4 **
** Invalid partition 5 **
** Invalid partition 6 **
** Invalid partition 7 **
It seems like that uboot run uname_boot and cause errors. My uEnv.txt has only one line as below
uname_r=6.12.13
So is this file right? If it’s wrong how can I generate the right uEnv.txt? If it’s right what should I do next?
Sincerely!
Here’s a log to help you see what it’s looking for:
loading /boot/vmlinuz-6.15.0-rc2-bone5 ...
8032768 bytes read in 511 ms (15 MiB/s)
debug: [enable_uboot_overlays=] ...
loading /boot/dtbs/6.15.0-rc2-bone5/am335x-boneblack-revd.dtb ...
100176 bytes read in 11 ms (8.7 MiB/s)
uboot_overlays: add [enable_uboot_overlays=1] to /boot/uEnv.txt to enable...
loading /boot/initrd.img-6.15.0-rc2-bone5 ...
8813626 bytes read in 567 ms (14.8 MiB/s)
debug: [console=ttyS0,115200n8 root=/dev/mmcblk0p3 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100] ...
debug: [bootz 0x82000000 0x88080000:867c3a 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x7a9200 ]
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f798000, end 8ffffc3a ... OK
   Loading Device Tree to 8f77c000, end 8f79774f ... OK
Starting kernel ...
You’ve set: uname_r=6.12.13
So its looking for an ext4 partition with /boot/vmlinuz-6.12.13
I used to read your tutorial on techforum and just think that you typed the wrong letter ! Because the ‘x’ and ‘z’ are near on keyboard. So I name the zImage vmlinux wrongly but not vmlinuz. Now the kernel has been found by uboot
Thank you very much~~
