Ubuntu 13.10 NO GUI (NO graphical user interface)
Hey There…
I followed this procedure and installed Ubuntu 13.10 in my BBB. Used the prebuilt image. (https://rcn-ee.net/deb/flasher/saucy/BBB-eMMC-flasher-ubuntu-13.10-2013-11-15.img.xz)
It was successful, but after installing it Im getting only a command line interface. Can I get a GUI somehow? Or is there a image with a GUI ???
Flasher[edit]
eMMC: BeagleBone Black[edit]
This image can be written to a 1Gb (or greater) microSD card, via ‘dd’ in linux or the win32 image program linked to on CircuitCo’s wiki page. First hold down on the boot select button (next to microSD card) and apply power (same procedure as the official CircuitCo images), it should boot into Ubuntu and begin flashing the eMMC, once completed all 4 LED’s should be full ON… Simply remove power, remove microSD card and Ubuntu will now boot from eMMC.
Script for Reference: (this is the script that writes to the eMMC)https://github.com/RobertCNelson/tools/blob/master/scripts/beaglebone-black-copy-microSD-to-eMMC.sh
BTW: we are only writing about 500Mb’s to the eMMC so the script will only take about 5-6 Minutes after power on.
Notes:
If only two LED’s stay lit and nothing happens, the board has crashed due to lack of power. Try with a 5Volt DC supply plugged in…
If the 4 LED’s blink a constant pattern, eMMC write failed, first REMOVE ALL capes, then retry again.
(error -84: which may mean you’ve reached the max number of erase/write cycles…)
User: ubuntu pass: temppwd
Image Updated:
2013-11-15
BeagleBone Black: v3.8.13-bone30 kernel
ssh host key fixes (auto generated on bootup…)
2013-10-25
Use 13.10 as base…
BeagleBone Black: v3.8.13-bone28 kernel
2013-10-08
4bit microSD operation…
fixed a dpkg search bug, which would make the flashing fail without network connection
Get prebuilt image:wget https://rcn-ee.net/deb/flasher/saucy/BBB-eMMC-flasher-ubuntu-13.10-2013-11-15.img.xz
Verify Image with:md5sum BBB-eMMC-flasher-ubuntu-13.10-2013-11-15.img.xz
2b1698990000baf45ac1c99572541f30 BBB-eMMC-flasher-ubuntu-13.10-2013-11-15.img.xz
Search the forum. This question was answered two hours ago. Just type GUI in the box and sort by date.
You have to install the GUI yourself.
Thanks man!
I have this same question. Where is it answered?
nooshi.bn86,您好!
You can use apt-get to install lxde easily. You may need to do some configurations.
Take a look at this link :
I had lxde runing farewell on my BBB.
======== 2014-03-06 10:18:31 您在来信中写道: ========
> Hello,
> On Friday, December 13, 2013 8:12:16 PM UTC-8, Dhanushka Jayaweera wrote:
> > Hey There…
> > <br>> > Flasher[[edit](http://elinux.org/index.php?title=BeagleBoardUbuntu&action=edit&section=9)]<br>> > eMMC: BeagleBone Black[[edit](http://elinux.org/index.php?title=BeagleBoardUbuntu&action=edit&section=10)]<br>> > <br>> > This image can be written to a 1Gb (or greater) microSD card, via 'dd' in linux or the win32 image program linked to on CircuitCo's wiki page. First hold down on the boot select button (next to microSD card) and apply power (same procedure as the official CircuitCo images), it should boot into Ubuntu and begin flashing the eMMC, once completed all 4 LED's should be full ON... Simply remove power, remove microSD card and Ubuntu will now boot from eMMC.<br>> > <br>> > Script for Reference: (this is the script that writes to the eMMC)[https://github.com/RobertCNelson/tools/blob/master/scripts/beaglebone-black-copy-microSD-to-eMMC.sh](https://github.com/RobertCNelson/tools/blob/master/scripts/beaglebone-black-copy-microSD-to-eMMC.sh)<br>> > <br>> > BTW: we are only writing about 500Mb's to the eMMC so the script will only take about 5-6 Minutes after power on.<br>> > <br>> > Notes:<br>> > If only two LED's stay lit and nothing happens, the board has crashed due to lack of power. Try with a 5Volt DC supply plugged in..<br>> > If the 4 LED's blink a constant pattern, eMMC write failed, first REMOVE ALL capes, then retry again.<br>> > (error -84: which may mean you've reached the max number of erase/write cycles...)<br>> > <br>> > User: ubuntu pass: temppwd<br>> > <br>> > Image Updated:<br>> > 2013-11-15<br>> > BeagleBone Black: v3.8.13-bone30 kernel<br>> > ssh host key fixes (auto generated on bootup...)<br>> > 2013-10-25<br>> > Use 13.10 as base...<br>> > BeagleBone Black: v3.8.13-bone28 kernel<br>> > 2013-10-08<br>> > BeagleBone Black: v3.8.13-bone28 kernel<br>> > 4bit microSD operation...<br>> > fixed a dpkg search bug, which would make the flashing fail without network connection<br>> > <br>> > Get prebuilt image:wget [https://rcn-ee.net/deb/flasher/saucy/BBB-eMMC-flasher-ubuntu-13.10-2013-11-15.img.xz](https://rcn-ee.net/deb/flasher/saucy/BBB-eMMC-flasher-ubuntu-13.10-2013-11-15.img.xz)<br>> > <br>> > Verify Image with:md5sum BBB-eMMC-flasher-ubuntu-13.10-2013-11-15.img.xz<br>> > 2b1698990000baf45ac1c99572541f30 BBB-eMMC-flasher-ubuntu-13.10-2013-11-15.img.xz<br>> > <br>> >
> For more options, visit http://beagleboard.org/discuss
> You received this message because you are subscribed to the Google Groups “BeagleBoard” group.
> To unsubscribe from this group and stop receiving emails from it, send an email to beagleboard+unsubscribe@googlegroups.com.
> For more options, visit https://groups.google.com/groups/opt_out.
> 在此邮件中未发现病毒。
> 检查工具:AVG - www.avg.com
> 版本:2014.0.4259 / 病毒数据库:3705/7157 - 发布日期:03/05/14
礼!
Yang
winglion1@163.com
2014-03-07
