Ubuntu image file for BeagleBone White?
I cannot seem to follow the directions here: http://elinux.org/BeagleBoardUbuntu
I have Ubuntu installed on a VirtualBox and I can’t see the SD card at all from there. I have the USB Vbox extensions installed too. Is there a .img file for the BeagleBoard white like there is for Angstrom? I am having a very hard time finding this information!
My end goal is to gain access to I2C driver, which as I understand is not available in the Angstrom Linux? I think that I need apt-get available in Ubuntu? I am trying to follow the instructions here, which uses a BeagleBone White running Ubuntu: http://derekmolloy.ie/beaglebone/beaglebone-an-i2c-tutorial-interfacing-to-a-bma180-accelerometer/
So I know that it can be done, but I will have to boot a true Linux distro to follow these instructions…hmmm maybe a live image will do?
Thanks, David.
As long as you have enough ram, you could just boot an ubuntu/debian
livecd, then also dl/run the sd card creating script..
You could also use the beaglebone black flasher image, just make sure
to drop the "flash-eMMC.txt" file in the boot partition and resize the
root partition to the full size of the drive..
I am still having a hard time following the instructions. Was I supposed to run the build_kernel.sh first, then unzip and run the setup_sdcard.sh script? It looked like that part was for “Advanced users only” which definitely is not me (yet.) I only did the second part of unzipping the ubuntu tar.gz file and I got no blinking lights on my BeagleBone. I saw popups from Linux GUI (live CD) that rootfs and boot don’t exist. So that kind of makes sense now that I have rebooted my PC back into Win7 :frowning: But the setup_sdcard.sh script did not throw any errors??
Also, what does this mean:
Active on Boot Script:
  • Disable by removing “run_boot-scripts” from small boot partition…*
How do I find such a thing, and why would I want to do it?
script? It looked like that part was for "Advanced users only" which
popups from Linux GUI (live CD) that rootfs and boot don't exist. So that
Are you "building" your own kernel/image? That's what
"./build_kernel.sh" etc is for..
If you just want to run a pre-built ready to go image..
http://elinux.org/BeagleBoardUbuntu#Raring_13.04_armhf
and follow the setup_sdcard.sh instructions..
Disable by removing "run_boot-scripts" from small boot partition...*
It's a 'file' on the boot partition, which does things like, enable
the musb slave and enables an ethernet over usb connection, sets the
clock to a date within a month vs 1970, etc..
