I built a new 2.6.38-rc1-git3 Ubuntu kernel with DEBUG_LL on Kubuntu 11.04 x86_64, but it doesn't boot and I get no debug messages.
Texas Instruments X-Loader 1.4.4ss (Sep 22 2010 - 16:12:19)
Beagle Rev C1/C2/C3
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.03-dirty (Sep 01 2010 - 16:53:27)
OMAP3530-GP ES3.0, CPU-OPP2, L3-165MHz, Max clock-600Mhz
I2C: ready
DRAM: 256 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Probing for expansion boards, if none are connected you'll see a harmless I2C error.
timed out in wait_for_pin: I2C_STAT=0
I2C read: I/O error
Unrecognized expansion board: 0
Beagle Rev C1/C2/C3
Die ID #6b22000300000000040323090d00a00a
mmc1 is available
reading uImage
2767300 bytes read
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Linux
Data Size: 2767236 Bytes = 2.6 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Used the following steps:-
"ARCH=ARM make omap2plus_defconfig" the "make menuconfig" previously.
ARCH=arm make oldconfig
make-kpkg --revision=0 --append-to-version=-custom --arch=armel --cross-compile=/opt/arm-2010q1/bin/arm-none-linux-gnueabi- kernel-headers kernel-image --initrd
Booted the Beagleboard C3, installed kernel-headers and linux-image.
Copied initrd.img-2.6.38-rc1-git3-custom and vmlinuz-2.6.38-rc1-git3-custom back to the x86_64 box.
mkimage -A arm -O linux -T kernel -C none -a 0x80008000 -e 0x80008000 -n "Linux" -d ./vmlinuz-* ./uImage
# Copy "uImage" to the Boot Partition
mkimage -A arm -O linux -T ramdisk -C none -a 0 -e 0 -n initramfs -d ./initrd.img-* ./uInitrd
# Copy "uInitrd" to the Boot Partition
Booted the beagleboard, but it stops as shown above.
I can supply my .config if requested.
Same problem trying to boot the Ubuntu ppa kernel 2.6.38-rc1-d0.
I copied back the original 2.6.35.6-l5 uImage and uInitrd on the SDHC and it boots.
I think I should have everything in place for a successful boot, I am out of clues.
Regards
Sid.
