I am trying to install Ubuntu according to
http://www.instructables.com/id/BeagleBone-Ubuntu-OS-LXDE-GUI/?ALLSTEPS
on a SD-Card and get this on the serial console while booting (the
heartbeat LED go into nervously flashing after this...):
U-Boot 2011.09-dirty (Feb 27 2012 - 10:01:37)
I2C: ready
DRAM: 256 MiB
No daughter card present
NAND: HW ECC Hamming Code selected
No NAND device found!!!
0 MiB
MMC: OMAP SD/MMC: 0
Net: cpsw
SD/MMC found on device 0
reading uEnv.txt
** Unable to read "uEnv.txt" from mmc 0:1 **
reading uImage
2642856 bytes read
## Booting kernel from Legacy Image at 80007fc0 ...
Image Name: Linux
Data Size: 2642792 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
XIP Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.23-psp18 (root@panda-es-b1-1gb) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 Fri Jul 27 20:46:04 UTC 2012
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[ 0.000000] Machine: am335xevm
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait ip=none
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 251272k/251272k available, 10872k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0699000 (6724 kB)
[ 0.000000] .init : 0xc0699000 - 0xc06d7000 ( 248 kB)
[ 0.000000] .data : 0xc06d8000 - 0xc0720360 ( 289 kB)
[ 0.000000] .bss : 0xc0720384 - 0xc0761d1c ( 263 kB)
[ 0.000000] NR_IRQS:410 nr_irqs:410 410
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000152] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[ 0.058563] pid_max: default: 32768 minimum: 301
[ 0.058685] Security Framework initialized
[ 0.058746] AppArmor: AppArmor initialized
[ 0.058807] Mount-cache hash table entries: 512
[ 0.059204] Initializing cgroup subsys cpuacct
[ 0.059234] Initializing cgroup subsys memory
[ 0.059265] Initializing cgroup subsys devices
[ 0.059295] Initializing cgroup subsys freezer
[ 0.059295] Initializing cgroup subsys blkio
[ 0.059326] Initializing cgroup subsys perf_event
[ 0.059387] CPU: Testing write buffer coherency: ok
[ 0.060363] devtmpfs: initialized
[ 0.079986] omap_hwmod: gfx: failed to hardreset
[ 0.096282] omap_hwmod: pruss: failed to hardreset
[ 0.096984] print_constraints: dummy:
[ 0.097229] NET: Registered protocol family 16
[ 0.098327] OMAP GPIO hardware version 0.1
[ 0.099395] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.100616] omap_i2c.1: alias fck already exists
[ 0.101013] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.101165] omap2_mcspi.1: alias fck already exists
[ 0.101287] omap2_mcspi.2: alias fck already exists
[ 0.101379] omap_init_sham: platform not supported
[ 0.101379] omap_init_aes: platform not supported
[ 0.101440] edma.0: alias fck already exists
[ 0.101470] edma.0: alias fck already exists
[ 0.101562] cape: pcm register
[ 0.109130] bio: create slab <bio-0> at 0
[ 0.110412] SCSI subsystem initialized
[ 0.111267] usbcore: registered new interface driver usbfs
[ 0.111419] usbcore: registered new interface driver hub
[ 0.111572] usbcore: registered new device driver usb
[ 0.111877] registerd cppi-dma Intr @ IRQ 17
[ 0.111907] Cppi41 Init Done Qmgr-base(d083a000) dma-base(d0838000)
[ 0.111938] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[ 0.112091] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[ 0.112548] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[ 0.113250] tps65910 1-002d: could not be detected
[ 0.113708] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.114257] NetLabel: Initializing
[ 0.114288] NetLabel: domain hash size = 128
[ 0.114288] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.114349] NetLabel: unlabeled traffic allowed by default
[ 0.114379] Switching to clocksource gp timer
[ 0.114593] AppArmor: AppArmor Filesystem Enabled
[ 0.124389] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.124633] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[ 0.124816] MUSB0 controller's USBSS revision = 4ea20800
[ 0.125549] musb-hdrc musb-hdrc.0: USB OTG mode controller at d081c000 using DMA, IRQ 18
[ 0.125823] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[ 0.125946] MUSB1 controller's USBSS revision = 4ea20800
[ 0.126373] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.126464] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.126586] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.126617] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.126647] usb usb1: Product: MUSB HDRC host driver
[ 0.126647] usb usb1: Manufacturer: Linux 3.2.23-psp18 musb-hcd
[ 0.126647] usb usb1: SerialNumber: musb-hdrc.1
[ 0.127258] hub 1-0:1.0: USB hub found
[ 0.127288] hub 1-0:1.0: 1 port detected
[ 0.127746] musb-hdrc musb-hdrc.1: USB Host mode controller at d081e800 using DMA, IRQ 19
[ 0.128173] NET: Registered protocol family 2
[ 0.128479] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.129272] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.129455] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.129547] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.129547] TCP reno registered
[ 0.129577] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.129577] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.129913] NET: Registered protocol family 1
[ 0.130310] RPC: Registered named UNIX socket transport module.
[ 0.130310] RPC: Registered udp transport module.
[ 0.130310] RPC: Registered tcp transport module.
[ 0.130340] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.132171] audit: initializing netlink socket (disabled)
[ 0.132232] type=2000 audit(0.110:1): initialized
[ 0.290222] VFS: Disk quotas dquot_6.5.2
[ 0.290344] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.291900] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.291961] fuse init (API version 7.17)
[ 0.292602] Btrfs loaded
[ 0.292633] msgmni has been set to 490
[ 0.293762] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.293884] io scheduler noop registered
[ 0.293884] io scheduler deadline registered
[ 0.293945] io scheduler cfq registered (default)
[ 0.295104] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.296203] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 0.990966] console [ttyO0] enabled
[ 0.995208] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 1.002929] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 1.010620] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 1.018280] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 1.025939] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 1.040374] brd: module loaded
[ 1.047515] loop: module loaded
[ 1.050872] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.114959] No daughter card found
[ 1.118560] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.133758] Board config.name: A335BONE00A62712BB000768
[ 1.139221] Board name: A335BONE
[ 1.142578] Board version: 00A6
[ 1.145843] The board is a AM335x Beaglebone.
[ 1.151031] tps65217 1-0024: TPS65217 ID 0xf version 1.1
[ 1.158386] print_constraints: DCDC1: 900 <--> 1800 mV at 1800 mV
[ 1.166656] print_constraints: DCDC2: 900 <--> 3300 mV at 1275 mV
[ 1.174896] print_constraints: DCDC3: 900 <--> 1500 mV at 1100 mV
[ 1.183105] print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV
[ 1.191345] print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV
[ 1.199493] print_constraints: LDO3: 1800 <--> 3300 mV at 3300 mV
[ 1.207733] print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV
[ 1.214660] cpufreq: disabling OPPTURBO (720mhz)
[ 1.219848] omap_i2c.3: alias fck already exists
[ 1.225036] omap_i2c omap_i2c.3: bus 3 rev2.4.0 at 100 kHz
[ 1.231475] omap_hsmmc.0: alias fck already exists
[ 1.239562] at24 3-0054: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.269958] BeagleBone cape EEPROM: found eeprom at address 0x54
[ 1.276245] BeagleBone cape: Beagleboardtoys. BeagleBone LCD7 CAPE............Beagleboardtoys., revision 00A2
[ 1.286590] BeagleBone cape partnumber: BB-BONE-LCD7-01.
[ 1.292114] BeagleBone cape: initializing LCD cape
[ 1.297546] da8xx_lcdc.0: alias fck already exists
[ 1.302825] da8xx_lcdc da8xx_lcdc.0: GLCD: Found TFC_S9700RTWV35TR_01B panel
[ 1.321197] Console: switching to colour frame buffer device 100x30
[ 1.334655] BeagleBone cape: initializing LCD cape touchscreen
[ 1.340759] TSC connected to BeagleBone
[ 1.345153] BeagleBone cape: Registering PWM backlight for LCD cape
[ 1.351684] BeagleBone cape: Registering gpio-keys for LCD cape
[ 1.358215] at24 3-0055: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.425018] BeagleBone cape EEPROM: could not read eeprom at address 0x55
[ 1.432159] at24 3-0056: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.494995] BeagleBone cape EEPROM: could not read eeprom at address 0x56
[ 1.502105] at24 3-0057: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[ 1.565002] BeagleBone cape EEPROM: could not read eeprom at address 0x57
[ 1.572082] BeagleBone cape: initializing w1-gpio
[ 1.577148] w1-gpio connected to P8_6
[ 1.581939] CAN device driver interface
[ 1.585998] CAN bus driver for Bosch D_CAN controller 1.0
[ 1.635009] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[ 1.641479] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[ 1.648986] davinci_mdio.0: probed
[ 1.652526] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver SMSC LAN8710/LAN8720
[ 1.661254] usbcore: registered new interface driver cdc_ether
[ 1.667419] usbcore: registered new interface driver rndis_host
[ 1.673614] cdc_ncm: 04-Aug-2011
[ 1.677062] usbcore: registered new interface driver cdc_ncm
[ 1.683044] Initializing USB Mass Storage driver...
[ 1.688262] usbcore: registered new interface driver usb-storage
[ 1.694519] USB Mass Storage support registered.
[ 1.699462] usbcore: registered new interface driver libusual
[ 1.705566] gadget: using random self ethernet address
[ 1.711029] gadget: using random host ethernet address
[ 1.717315] usb0: MAC 4a:77:87:cf:f4:83
[ 1.721313] usb0: HOST MAC 72:d8:83:fe:c1:5c
[ 1.725860] gadget: Ethernet Gadget, version: Memorial Day 2008
[ 1.732116] gadget: g_ether ready
[ 1.735687] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 1.741302] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 1.749176] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.756256] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.763793] usb usb2: Product: MUSB HDRC host driver
[ 1.768981] usb usb2: Manufacturer: Linux 3.2.23-psp18 musb-hcd
[ 1.775177] usb usb2: SerialNumber: musb-hdrc.0
[ 1.780548] hub 2-0:1.0: USB hub found
[ 1.784484] hub 2-0:1.0: 1 port detected
[ 1.789428] mousedev: PS/2 mouse device common for all mice
[ 1.796234] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
[ 1.802886] omap_rtc: already running
[ 1.806823] i2c /dev entries driver
[ 1.810852] Linux media interface: v0.10
[ 1.815093] lirc_dev: IR Remote Control driver registered, major 249
[ 1.821807] Driver for 1-wire Dallas network protocol.
[ 1.828491] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.840301] cpuidle: using governor ladder
[ 1.844787] cpuidle: using governor menu
[ 1.851989] usbcore: registered new interface driver usbhid
[ 1.857879] usbhid: USB HID core driver
[ 1.862976] usbcore: registered new interface driver snd-usb-6fire
[ 1.870056] ALSA device list:
[ 1.873168] No soundcards found.
[ 1.877960] TCP cubic registered
[ 1.881500] NET: Registered protocol family 10
[ 1.889617] NET: Registered protocol family 17
[ 1.894470] can: controller area network core (rev 20090105 abi 8)
[ 1.901123] NET: Registered protocol family 29
[ 1.905822] can: raw protocol (rev 20090105)
[ 1.910369] Registering the dns_resolver key type
[ 1.915374] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 1.923370] ThumbEE CPU extension supported.
[ 1.927917] mux: Failed to setup hwmod io irq -22
[ 1.933593] Power Management for AM33XX family
[ 1.944000] registered taskstats version 1
[ 1.948730] Detected MACID=d4:94:a1:99:9b:82
[ 1.957275] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 1.964752] omap_rtc omap_rtc: setting system clock to 2000-01-01 05:38:35 UTC (946705115)
[ 1.974304] Waiting for root device /dev/mmcblk0p2...
[ 2.015838] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 2.026245] mmc0: new high speed SDHC card at address b368
[ 2.032623] mmcblk0: mmc0:b368 TF16G 14.8 GiB
[ 2.039062] mmcblk0: p1 p2
[ 2.103973] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.112579] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.122497] devtmpfs: mounted
[ 2.126220] Freeing init memory: 248K
[ 2.224578] gadget: high-speed config #1: CDC Ethernet (ECM)
[ 2.410400] init: Failed to create pty - disabling logging for job
[ 2.425567] init: Temporary process spawn error: No such file or directory
[ 2.480255] init: Failed to create pty - disabling logging for job
[ 2.505767] init: Temporary process spawn error: No such file or directory
[ 2.518585] init: Failed to create pty - disabling logging for job
[ 2.535736] init: Temporary process spawn error: No such file or directory
[ 2.561279] init: Failed to create pty - disabling logging for job
[ 2.575561] init: Temporary process spawn error: No such file or directory
[ 2.664978] init: ureadahead main process (55) terminated with status 5
[ 2.886169] init: Failed to create pty - disabling logging for job
[ 2.892944] init: Temporary process spawn error: No such file or directory
[ 2.947143] init: Failed to create pty - disabling logging for job
[ 2.953887] init: Temporary process spawn error: No such file or directory
[ 3.087585] init: Failed to create pty - disabling logging for job
[ 3.094360] init: Temporary process spawn error: No such file or directory
[ 3.230590] init: Failed to create pty - disabling logging for job
[ 3.245910] init: Temporary process spawn error: No such file or directory
[ 3.272399] init: Failed to create pty - disabling logging for job
[ 3.285858] init: Temporary process spawn error: No such file or directory
[ 3.312774] init: Failed to create pty - disabling logging for job
[ 3.325866] init: Temporary process spawn error: No such file or directory
[ 3.903442] init: Failed to create pty - disabling logging for job
[ 3.926147] init: Temporary process spawn error: No such file or directory
[ 3.940246] init: Failed to create pty - disabling logging for job
[ 3.966308] init: Temporary process spawn error: No such file or directory
[ 4.016754] init: Failed to create pty - disabling logging for job
[ 4.023529] init: Temporary process spawn error: No such file or directory
[ 4.130218] init: Failed to create pty - disabling logging for job
[ 4.258514] init: Failed to create pty - disabling logging for job
[ 4.316162] init: Failed to create pty - disabling logging for job
[ 4.375549] init: Failed to create pty - disabling logging for job
[ 5.011932] init: Failed to create pty - disabling logging for job
[ 5.057891] init: Failed to create pty - disabling logging for job
[ 5.112884] init: Failed to create pty - disabling logging for job
[ 5.253112] init: Failed to create pty - disabling logging for job
[ 5.310699] init: Failed to create pty - disabling logging for job
What is going on here? Is mz beaglebone damaged?
Thank you very much in advance for any help!
Best regards,
mcc
