I can successfully run Ubuntu 10.04 on Devkit8000. The kernel is
2.6.37-x2, thanks very much to Robert Nelson. The Ubuntu image was
obtained following the instructions on http://elinux.org/BeagleBoardUbuntu.
I am using u-boot 2011.06 compiled for Devkit8000.
The problem encountered was no display was seen at the DVI output.
I had to run setup_sdcard.sh with the option "--use-default-user" to
log in using the serial port for further investigation. However, I am
at a loss over how to proceed. Could someone advise? Like what
commands to probe the cause of the problem? Sorry for my stupid
questions.
obtained following the instructions on BeagleBoardUbuntu - eLinux.org.
Why the 10.04 image? You should really retest with the newer 11.04
image with the v3.0.1 kernel... The Devkit8000 doesn't get a whole
lot of love as developers who have the board seem to come an go..
questions.
> Hi,
> obtained following the instructions onhttp://elinux.org/BeagleBoardUbuntu.
I would have bought a beagleboard if I could. For some stupid reason,
beagleboard requires a license from US to be sold in my country of
residence. I reside in Singapore now which is obviously not a
terrorist-prone country. Quite the other way round with the country
being a terrorist target because of its strong political leanings
towards the US.
By the way, I managed to borrow a TI AM37x evaluation module with
WL1271 wireless support temporarily. May I know if your kernel is able
to support TI AM37x? I am using 2.6.37-x2. Thanks.
I'd still try the v3.0.x kernel on the DevKit8000...
These demo images: http://elinux.org/BeagleBoardUbuntu#Demo_Image have
that v3.0.x kernel..
Otherwise i'm sorry but i pushed out 2.6.37-x2 on January 29, 2011,
there's been many kernels between that and now..
>> > Hi,
> towards the US.
These demo images:BeagleBoardUbuntu - eLinux.org
No problem. Your website has been a great help already. May I ask
which compiler did you use for your kernels? I would like to use the
same one. It would be great if you could tell me the compiler to use
for 2.6.37 and 3.0. Thank you. The kernels I compiled without changing
anything (just run build_kernel.sh) had problems booting up. For
example, your kernel size is 4.1MB. Mine is 4.4MB using kernel
2.6.37x2.
I have tried using Code Sourcery arm-2011.03-42-arm-none-eabi.bin and
arm-2011.03-41-arm-none-linux-gnueabi.bin. Both generated uImage of
4.4MB size.
>> > Hi,
> towards the US.
2.6.37x2.
Most of the time I actually use the ubuntu/linaro cross compiler, or
Angstrom's 4.3.x gcc:
natty: gcc version 4.5.2 (Ubuntu/Linaro 4.5.2-8ubuntu3)
(in ubuntu: sudo apt-get install gcc-arm-linux-gnueabi)
3.2M : deploy/3.0.2-x2.uImage
Alot of the size difference is from using lzma compression, which i
didn't have enabled in the 2.6.37's snapshots..
4.4MB size.
