i'am trying to run opencv with the python binding on a beagleboard C3
running Ubuntu Lucid. Everything works fine, but very slow. With
python script only capturing frames, i only get 10 frame/sec. When
running some ball detection i get 4 frame/sec. Do you have any idea
why it is so slow ... I will give a try at angstrom to see if the
problem comes from the OS.
On a C3 board with Ubuntu 9.04 and OpenCV 1.0, I ended up using SDL for the image capture and then extracting intensity values to an OpenCV matrix for image processing. This led to a student’s successful walking robot processing 10 fps from a Logitech 9000.
To begin to identify your problem, I suggest you try open-source luvcview and see how many frames per second it gives.
I have tested openCV on various Angstrom versions as have others.
It is a slug with video capture and any image processing, period.
On the bright side I see there is a GSoC proposal for a faster
openCV
I have not tried the latest Angstrom version (2.0 i believe).
I dnload sources and build my own native.
openCV
Whoever takes that takes has my deepest sympathies. OpenCV is written
in monstrous C++ sprinkled with x86 inline asm. Adding ARM
optimisations is going to be a bitch. The inline asm simply isn't
expressive enough to write efficient NEON code.
HoughCircles can take some time, but it appear that with better
binarized image it become slower than thresholding. I now use adaptive
threshold on the gray scale image, and then some erode and i get
better results. The drawback is that now i spend more time on
threshold + erode than HoughCircle. I can now get 4 frames/s with
320x240 frames, and 2 frames/s with 640x480 frames. It seems that i
need les erode steps with 640x480 frames. I guess that recoding some
parts with NEON intrinsics coud help.
