hi
i tried the setup_sdcard.sh that you recommend with the ubuntu lucid
demo images. i get a few errors, but the script continues. you have
#!/bin/bash -e
at the top, which should stop at errors. but because you advise to run
as
". setup_sdcard.sh --mmc /dev/sdX"
i think the shebang line is ignored. i think the shebang is only read
when you invoke the script like
"./setup_sdcard.sh --mmc /dev/sdX"
once this is enabled the script needs lines 25 and 26 changed to
sudo umount ${MMC}1 || true
sudo umount ${MMC}2 || true
the script can also fail if there are more that 2 partitions on the
disk, eg boot, root swap. it might be best to create a new disklabel
instead of trying to delete the partitions.
sudo fdisk ${MMC} << CLEAN
o
p
w
CLEAN
also i am having trouble booting. with the new method of using a
boot.src file, boot always stops at
Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.03-rc1 (Apr 01 2010 - 06:56:39)
OMAP3530-GP ES3.0, CPU-OPP2, L3-165MHz, Max clock-600Mhz
I2C: ready
if i hold down user at boot then it boots ok.
do i need to update the u-boot on the board? i have a C3
Sam
