I downloaded the image and wrote it to a 32GB microSD card, then inserted into a BBB that would otherwise be running Debian Wheezy from the eMMC, using the following steps:
Shutdown BBB (sudo halt)
When powered off, Insert microSD card
Push and hold User/Boot button, then reapply power
After a few seconds let go of User/Boot button
The image will not boot at all after this - none of the LEDs come on. (I’m assuming that they would also come on in the standard order on the Ubuntu image if everything were going right.)
What’s even more puzzling, when I insert the microSD card into the BBB while it is booted from eMMC (into Debian Wheezy) to inspect it, the system freezes within about 1-2 minutes. Upon rebooting from eMMC, the syslog suggests that the system ran into out of memory and the OOM killer was active. I’m stumped as to why and how this can happen simply from inserting the card.
The card otherwise works fine - I can put Debian Wheezy images on it and boot them just fine. When the Ubuntu snappy image is flashed on the card, the FAT boot partition with which it mounts on MacOSX looks OK. The uEnv.txt file on there is zero bytes, but based on what I can find online, Ubuntu has moved away from using the uEnv.txt file, so I think this being zero bytes may well be a red herring.
This being the one official image for the BBB for Ubuntu snappy core, I feel I must have done something wrong, but I don’t see what and where. Any suggestions would be much appreciated.
if this is the first time running from the uSD card then how about using a known good image just to verify you’ve got things booting correctly? Then you’ll know it’s your image and not something else.
That’s why I said the card otherwise works fine. I’ve used it to burn to the card and boot from the card the BBB Debian Wheezy 7.8 (March 1) and 7.9 (Nov 12) images, with everything working fine. It’s specifically when I turn to the Ubuntu image that things turn awry.
But perhaps that’s because the Ubuntu image requires some additional steps that I’m missing. For example, perhaps I need to zero out the first 512 or 1024 bytes of the device. It didn’t say that anywhere, which is why I didn’t do it. But maybe the fact that I had previously other images on it somehow makes that necessary (even though I wouldn’t think so).
I’d be especially curious whether everyone else here has been able to use the Ubuntu Snappy Core 15.04 image just fine, so that I know it’s something with what I’m doing or something perhaps with the boot loader on my eMMC. (Even though I thought that if you press the User/Boot button, it disables that boot loader and changes boot order to the microSD? And that still doesn’t explain the weird OOM error I get when inserting the card into the running system.)
Also, if there’s a better place to ask than here, let me know.
If found that by googling “ubuntu core beaglebone black” and picking the “Getting Started / Developer” link. I like the developer links because they generally explain things and describe the why part of operations. On the link I provided you will see where they answer your question about zero’ing out the boot loader, or not and why.
Given those instructions it’s tough to say where your failure originates.
I suppose I can run through the steps and see what I get. Stay tuned.
Yes. That’s indeed the link I put in my original post.
Yes, except that what they talk about zeroing out the boot loader on the eMMC (not the SD card). I do want to keep the eMMC-resident boot loader, and based on what that documentation says, that’s OK and only requires pushing the user/boot button (which I did).
That’d be great. I’ve gotten to the point now that I can insert the card to a running system on the BBB for inspection, without crashing it as a result. I downloaded the image again, this time using curl, and then burned it to the SD card again. Now the partition layout shows as they say it should:
$ sudo fdisk -l /dev/mmcblk0
Disk /dev/mmcblk0: 32.2 GB, 32227983360 bytes
4 heads, 32 sectors/track, 491760 cylinders, total 62945280 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0xa3c9235b
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 * 8192 270335 131072 c W95 FAT32 (LBA)
/dev/mmcblk0p2 270336 2367487 1048576 83 Linux
/dev/mmcblk0p3 2367488 4464639 1048576 83 Linux
/dev/mmcblk0p4 4464640 7614463 1574912 83 Linux
The p2 and p3 partitions are labeled system-a and system-b, p4 is labeled ‘writable’ and p1 is labeled system-boot, all as they are supposed to be. p1 is bootable.
However, booting from it still fails. No LEDs ever light, everything except the power LED stays dark.
what I got so far looks like it’s booting from mmcblk0( the uSD ) but then it goes into wanting to copy all 30GB from mmcblk0p1 to mmcblk1p1 and it fails for obvious reasons. I’m switching to a 8GB uSD card just to see what happens when it is able to complete. I don’t know why it would want to flash eMMC…
I have no idea of this image, ubuntu is not necessarily even a low priority for me. But I would imagine one could simply omit the block size parameter entirely.
Regardless, I’m downloading the image now, and will mount it as a loopback, and see what I can poke around and find out. Maybe even temp install to sdcard, as the instructions are not exactly complex, or hard . . . being only 4 simple commands.
for whatever reason I could not get it to boot back into the uSD and it started to go back to flashing(cylon eyes). I looked at the partitions and there were only 2. After re-imaging the uSD card, I saw 4 partitions. And while I was re-imaging I tried to boot from eMMC and it would not, the failed flashing left the eMMC goofed up.
But the good news is, once I finished re-imaging, I booted and got back into Ubuntu Snappy Core. Another thing of interest is that while I held down the S2/User/Boot button I didn’t get any LEDs lit but it started booting into the uSD card so I let go of the button. It took a minute of booting/testing before it went to town and started loading from uSD(ie LEDs ablaze).
I don’t know why the 32G Samsung didn’t work but I may have forgot what’s the max uSD size for BBB is.
Technically, sdhc size, or 32G, but in reality, sdxc have been proven to work as well. At sdhc speeds. Robert’s gotten a 64G to work, and someone else claimed to have had a bootable 128G sdxc card.
Thanks much for your efforts. For one, your results were the final nudge I needed to buy a USB to TTL serial debug cable. It’s possible that I didn’t have enough patience with LEDs all dark and not being able to see any indications of it actually booting. From booting the BeagleBoard Debian Wheezy images from uSD I was used to seeing the LEDs come on very quickly, so I was apparently mistaken to assume this would be the same for the Snappy Core image.
Second, the fact that booting the image flashed your eMMC is not cool. I was in fact wondering whether it would or not. The documentation is silent about this question, and the file name of the image contains no suggestion that it flashes the eMMC. On AskUbuntu, someone actually asked whether there is a flasher image: http://askubuntu.com/questions/713604/snappy-on-beaglebone-black-or-green
The answer basically repeats the documentation from developer.ubuntu.com (which does not say anything about flashing versus not), and upon being specifically asked in the comments by people for whom the image failed to flash the eMMC, the poster admits they don’t know about that part. I also tried to glean the answer from the snappy-boot.txt file that it uses instead of the uEnv.txt, but there’s nothing in there that obviously indicates that the eMMC will be flashed.
To me, whether booting the image will or will not flash your eMMC is a rather important distinction, so to me this is a red flag. On top of that, based on what I can find 15.04 is only available as Snappy Core for armhf systems, which means that even just basic things such as installing apache become a huge hassle: http://askubuntu.com/questions/694397/how-to-install-apache-on-a-raspberry-pi-2-ubuntu-snappy-core
Based on this experience, while they have nice looking websites, I’m afraid the Ubuntu folks don’t have their act together for Ubuntu on BBB, and as a consequence I’ll stay away from them and their images for now.
ok so I re-imaged the 32G Samsung EVO+ card and it works. Not sure why it didn’t earlier but oh well.
So what kernel were you looking for? 4.x? If so it would seem Snappy Core for Banana Pi has kernel 4.x so it should be doable for BBB. Just not yet ‘done’.
From what I noticed, on the first partition ( vfat ) there are two boot options. One strictly boot, and one flash. e.g. two different initrd’s etc.
I’m guessing that the boot loader does some of that early LED flashing and since Snappy has its own boot loader on the uSD there’s not initial flashy LEDs
It could be I held the button too long or not long enough. I’ve not seen it try to flash now even though the eMMC doesn’t have a boot able image now. I’m thinking that was cockpit error.
I would think Debian and/or standard Ubuntu are still the best go-to OS’s for these devices(BBB, rPi, etc). For me at least for now.
Quite honestly, I have no interest in Ubuntu on this platform. For me, this is a true embedded platform, unlike many other boards out there. With that said, 99% of use cases that I can think of do not require a UI running on the board it’s self, per se. Which is the only place I feel Ubuntu belongs( mostly in the context of desktops )
Anyway, headless, and perhaps a minimal webserver( etc ) for remote access / management is what I prefer, and for that role Ubuntu is not the right distro.
