Ubuntu is booting without splash on beaglebaord (text log is shown on
screen). I guess that's plymouth. How can i show splash image instead?
I would like to put particular image but I'll be happy to start with
built-one.
I know that there are some problems related to DRM, etc.
Did anyone know how this can be achieved?
Well, if you remove the "console=tty0" from the "optargs" variable in
uEnv.txt file on the fat 'boot' partition, it'll at-least stop showing
the text log.
Then the frame-buffer version of the plymouth startup screen should work..
That removed most of the messages but some of them are still there. No
frame-buffer version yet.
Any idea?
Is there anything else to redirect?
уторак, 20. март 2012. 23.33.05 UTC+1, Predrag Manojlović је написао/ла:
Stupid of me…
optargs= splash quiet
is enough
уторак, 27. март 2012. 00.32.37 UTC+2, Predrag Manojlović је написао/ла:
Using your isntructions and
optargs= splash quietdid the job.
Now i have Ubuntu screen shown having progress bar (4 dots).
Now i cannot change theme:
I installed new theme i created in /lib/plymoyth/themes/THEMENAME
executed
sudo update-initramfs -u
When i manually start
plymouth show-splash
i get splash screen, but on boot is still shown default Ubuntu splash
Any idea?
четвртак, 08. март 2012. 22.23.00 UTC+1, RobertCNelson је написао/ла:
Problem solved.
Do not forget to run at the end
/boot/uboot/tools/update_boot_files.sh
субота, 05. мај 2012. 21.15.53 UTC+2, Predrag Manojlović је написао/ла:
