Hi, all
i am using latest kernel-2.6.28-r11 uImage .The following kernel-panic error has occured
previous case i have used 2.6.27-r12 uImage it worked well.
is there any change in bootargs for new kernel uImage
Texas Instruments X-Loader 1.41
Starting OS Bootloader…
U-Boot 1.3.3 (Jul 10 2008 - 16:33:09)
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
OMAP3 Beagle Board + LPDDR/NAND
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Audio Tone on Speakers … complete
OMAP3 beagleboard.org # setenv bootargs ‘console=ttyS2,115200n8 console=tty0 root=/dev/mmcblk0p2 rootdelay=2 rootfstype=ext3’
OMAP3 beagleboard.org # setenv bootcmd ‘mmcinit;fatload mmc 0 0x80300000 uImage;bootm 0x80300000’;
OMAP3 beagleboard.org # saveenv
Saving Environment to NAND…
Erasing Nand…Writing to Nand… done
OMAP3 beagleboard.org # run bootcmd
reading uImage
2587848 bytes read
Booting kernel from Legacy Image at 80300000 …
Image Name: Angstrom/2.6.28/beagleboard
Data Size: 2587784 Bytes = 2.5 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
Uncompressing Linux…
Linux version 2.6.28-omap1 (gvrao@ubuntutestpc) (gcc version 4.2.1) #1 Wed Jan 28 12:32:30 IST 2009
CPU: ARMv7 Processor [411fc082] revision 2 (ARMv7), cr=10c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP3 Beagle Board
Memory policy: ECC disabled, Data cache writeback
OMAP3430 ES2.1
SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
Reserving 15728640 bytes SDRAM for VRAM
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: console=ttyS2,115200n8 console=tty0 root=/dev/mmcblk0p2 rootdelay=2 rootfstype=ext3
Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
GPMC revision 5.0
IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP34xx GPIO hardware version 2.5
PID hash table entries: 512 (order: 9, 2048 bytes)
OMAP clockevent source: GPTIMER12 at 32768 Hz
Console: colour dummy device 80x30
console [tty0] enabled
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 108984KB available (4780K code, 425K data, 188K init)
Calibrating delay loop… 478.91 BogoMIPS (lpj=1867776)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 532 bytes
regulator: core version 0.5
NET: Registered protocol family 16
Found NAND on CS0
Registering NAND on CS0
OMAP DMA hardware revision 4.0
USB: No board-specific platform config found
OMAP DSS rev 2.0
OMAP DISPC rev 3.0
OMAP VENC rev 2
OMAP DSI rev 1.0
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368…375
twl4030: power (irq 373) chaining IRQs 376…383
twl4030: gpio (irq 368) chaining IRQs 384…401
i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
SCSI subsystem initialized
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
musb_hdrc: USB OTG mode controller at d80ab000 using DMA, IRQ 92
regulator: VMMC1: 1850 <–> 3150 mV normal standby
regulator: VDAC: 1800 mV normal standby
regulator: VUSB1V5: 1500 mV normal standby
regulator: VUSB1V8: 1800 mV normal standby
regulator: VUSB3V1: 3100 mV normal standby
regulator: VSIM: 1800 <–> 3000 mV normal standby
Bluetooth: Core ver 2.13
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: US
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
(5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
cfg80211: Calling CRDA for country: US
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) (SUMMARY) �ԩ 2001-2006 Red Hat, Inc.
msgmni has been set to 213
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver zd1211rw
usbcore: registered new interface driver rndis_wlan
usbcore: registered new interface driver zd1201
usbcore: registered new interface driver usb8xxx
usbcore: registered new interface driver rtl8187
usbcore: registered new interface driver rt2500usb
usbcore: registered new interface driver rt73usb
usbcore: registered new interface driver p54usb
i2c /dev entries driver
input: triton2-pwrbutton as /class/input/input0
triton2 power button driver initialized
Driver ‘sd’ needs updating - please use bus_type methods
Driver ‘sr’ needs updating - please use bus_type methods
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit)
cmdlinepart partition parsing not available
Creating 5 MTD partitions on “omap2-nand”:
0x00000000-0x00080000 : “X-Loader”
0x00080000-0x00260000 : “U-Boot”
0x00260000-0x00280000 : “U-Boot Env”
0x00280000-0x00680000 : “Kernel”
0x00680000-0x10000000 : “File System”
ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
Initializing USB Mass Storage driver…
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
g_ether gadget: using random self ethernet address
g_ether gadget: using random host ethernet address
usb0: MAC 02:31:cd:b3:90:ae
usb0: HOST MAC 4e:ca:89:cf:04:e4
g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
g_ether gadget: g_ether ready
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mice: PS/2 mouse device common for all mice
input: gpio-keys as /class/input/input1
twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
Bluetooth: HCI USB driver ver 2.10
usbcore: registered new interface driver hci_usb
Bluetooth: Broadcom Blutonium firmware driver ver 1.2
usbcore: registered new interface driver bcm203x
Bluetooth: Digianswer Bluetooth USB driver ver 0.10
usbcore: registered new interface driver bpa10x
Bluetooth: Generic Bluetooth SDIO driver ver 0.1
mmci-omap-hs mmci-omap-hs.0: Failed to get debounce clock
Registered led device: beagleboard::usr0
Registered led device: beagleboard::usr1
leds-gpio: probe of leds-gpio failed with error -22
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.18rc3.
usbcore: registered new interface driver snd-usb-audio
ASoC version 0.13.2
OMAP3 Beagle SoC init
TWL4030 Audio Codec init
asoc: twl4030 <-> omap-mcbsp-dai-(link_id) mapping ok
ALSA device list:
#0: omap3beagle (twl4030)
oprofile: using arm/armv7
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Bluetooth: L2CAP ver 2.11
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO (Voice Link) ver 0.6
Bluetooth: SCO socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.10
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright © 2004-2005 Intel Corporation <jketreno@linux.intel.com>
ThumbEE CPU extension supported.
Power Management for TI OMAP3.
SmartReflex driver initialized
Disabling unused clock “sr2_fck”
Disabling unused clock “sr1_fck”
Disabling unused clock “mcbsp_fck”
Disabling unused clock “mcbsp_ick”
Disabling unused clock “gpt2_ick”
Disabling unused clock “gpt3_ick”
Disabling unused clock “gpt4_ick”
Disabling unused clock “gpt5_ick”
Disabling unused clock “gpt6_ick”
Disabling unused clock “gpt7_ick”
Disabling unused clock “gpt8_ick”
Disabling unused clock “gpt9_ick”
Disabling unused clock “wdt3_ick”
Disabling unused clock “wdt3_fck”
Disabling unused clock “gpio2_dbck”
Disabling unused clock “gpio3_dbck”
Disabling unused clock “gpio4_dbck”
Disabling unused clock “gpio5_dbck”
Disabling unused clock “gpio6_dbck”
Disabling unused clock “gpt9_fck”
Disabling unused clock “gpt8_fck”
Disabling unused clock “gpt7_fck”
Disabling unused clock “gpt6_fck”
Disabling unused clock “gpt5_fck”
Disabling unused clock “gpt4_fck”
Disabling unused clock “gpt3_fck”
Disabling unused clock “gpt2_fck”
Disabling unused clock “gpt1_ick”
Disabling unused clock “wdt1_ick”
Disabling unused clock “wdt2_ick”
Disabling unused clock “wdt2_fck”
Disabling unused clock “gpio1_dbck”
Disabling unused clock “gpt1_fck”
Disabling unused clock “cam_ick”
Disabling unused clock “cam_mclk”
Disabling unused clock “des1_ick”
Disabling unused clock “sha11_ick”
Disabling unused clock “rng_ick”
Disabling unused clock “aes1_ick”
Disabling unused clock “ssi_ick”
Disabling unused clock “mailboxes_ick”
Disabling unused clock “gpt10_ick”
Disabling unused clock “gpt11_ick”
Disabling unused clock “i2c_ick”
Disabling unused clock “mcspi_ick”
Disabling unused clock “hdq_ick”
Disabling unused clock “mspro_ick”
Disabling unused clock “des2_ick”
Disabling unused clock “sha12_ick”
Disabling unused clock “aes2_ick”
Disabling unused clock “icr_ick”
Disabling unused clock “pka_ick”
Disabling unused clock “ssi_ssr_fck”
Disabling unused clock “hdq_fck”
Disabling unused clock “mcspi_fck”
Disabling unused clock “i2c_fck”
Disabling unused clock “mspro_fck”
Disabling unused clock “gpt11_fck”
Disabling unused clock “gpt10_fck”
Disabling unused clock “dpll4_m6x2_ck”
Disabling unused clock “dpll3_m3x2_ck”
Disabling unused clock “sys_clkout1”
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
Console: switching to colour frame buffer device 80x30
clock: clksel_round_rate_div: dpll4_m4_ck target_rate 48000000
clock: new_div = 9, new_rate = 48000000
twl4030_rtc twl4030_rtc: setting system clock to 2000-01-01 00:01:15 UTC (946684875)
Waiting 2sec before mounting root device…
mmc0: error -110 whilst initialising MMC card
Root-NFS: No NFS server available, giving up.
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device “mmcblk0p2” or unknown-block(2,0)
Please append a correct “root=” boot option; here are the available partitions:
1f00 512 mtdblock0 (driver?)
1f01 1920 mtdblock1 (driver?)
1f02 128 mtdblock2 (driver?)
1f03 4096 mtdblock3 (driver?)
1f04 255488 mtdblock4 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
tilak
