I’m trying to migrate to 4.1 from 3.8, and it seems as if the PRU is up and running on the latest 4.1 kernel. However, a difference is the I’m not getting the 8 uioX (x=0-8) entries in the /dev directory, and therefore the prussdrv library errors out when it can’t find those files.
The prussdrv is looking for this:
sprintf(name, “/dev/uio%d”, host_interrupt);
The dmesg output on 4.1.13-ti-r33 reports that it is skipping intr mapping…
[ 20.830764] pru-rproc 4a334000.pru0: version 0 event_chnl_map_size 1 event_chnl_map 0000039c
[ 20.830799] pru-rproc 4a334000.pru0: sysevt-to-ch[60] → 0
[ 20.830812] pru-rproc 4a334000.pru0: chnl-to-host[0] → 0
[ 20.830823] pru-rproc 4a334000.pru0: skip intr mapping for chnl 1
[ 20.830833] pru-rproc 4a334000.pru0: skip intr mapping for chnl 2
[ 20.830844] pru-rproc 4a334000.pru0: skip intr mapping for chnl 3
[ 20.830854] pru-rproc 4a334000.pru0: skip intr mapping for chnl 4
[ 20.830864] pru-rproc 4a334000.pru0: skip intr mapping for chnl 5
[ 20.830875] pru-rproc 4a334000.pru0: skip intr mapping for chnl 6
[ 20.830885] pru-rproc 4a334000.pru0: skip intr mapping for chnl 7
[ 20.830896] pru-rproc 4a334000.pru0: skip intr mapping for chnl 8
[ 20.830906] pru-rproc 4a334000.pru0: skip intr mapping for chnl 9
Does anyone know how to not skip that? Or a way for me to map them manually?
Erik
              The TI kernels have remoteproc enabled in the kernel, which will interfere with uio_pruss. You need to switch to a bone  kernel.
              The kernel I’m using by the way . . .
$ uname -a
Linux beaglebone 4.1.9-bone-rt-r16 #1  Thu Oct 1 06:19:41 UTC 2015 armv7l GNU/Linux
$ ls /dev/ |grep uio
uio
uio0
uio1
uio2
uio3
uio4
uio5
uio6
uio7
$ ./lsuio
uio7: name=pruss_evt7, version=1.0, events=0
map[0]: addr=0x4A300000, size=524288
map[1]: addr=0x9E880000, size=262144
uio6: name=pruss_evt6, version=1.0, events=0
uio5: name=pruss_evt5, version=1.0, events=0
uio4: name=pruss_evt4, version=1.0, events=0
uio3: name=pruss_evt3, version=1.0, events=0
uio2: name=pruss_evt2, version=1.0, events=0
uio1: name=pruss_evt1, version=1.0, events=0
uio0: name=pruss_evt0, version=1.0, events=0
              hmmm, i don’t see that on 4.1.13-bone16. Maybe I need to use 4.1.13-bone-rt-r16? What is the difference between the bone and bone-rt?
              bone-rt has real time enhancements. I do not know all the differences, but the kernel latency seems to be reduced.
Anyway, you do not see what ?
              By the way, I had to make my own device tree overlay for the PRU. It’s pretty simple. . . .
/dts-v1/;
/plugin/;
compatible = “ti,beaglebone”, “ti,beaglebone-black”;
/* identification */
part-number = “pru_enable”;
version = “00A0”;
fragment@0 {
target = <&pruss>;
overlay  {
status = “okay”;
$ dtc -O dtb -o pru_enable-00A0.dtbo -b 0 -@ pru_enable-00A0.dts
$ sudo cp pru_enable-00A0.dtbo /lib/firmware/
$ sudo sh -c “echo ‘pru_enable’ > /sys/devices/platform/bone_capemgr/slots”
$ dmesg | grep pru_enable
[ 886.921624] bone_capemgr bone_capemgr: part_number ‘pru_enable’, version ‘N/A’
[ 886.941686] bone_capemgr bone_capemgr: slot #6:  ‘Override Board Name,00A0,Override Manuf,pru_enable’
[ 886.981959] bone_capemgr bone_capemgr: slot #6:  dtbo ‘pru_enable-00A0.dtbo’ loaded; overlay id #0
              William,
I installed the 4.1.13-bone-rt-r16 kernel, and the /dev/uioX entires showed up. I guess I’ll try using this one. Thanks for the help!
Erik
                Micka
                    November 23, 2015,  4:41pm
              8
              Hi, did you managed to make this kernel working with the PRU ? Because I got that :
https://www.mail-archive.com/beagleboard@googlegroups.com/msg32826.html
Micka,
              Micka,
TI 4.x kernels will not work with “traditional” PRU stuff. TI kernels have remoteproc enabled. . . which takes over the PRU in a different way.
                Micka
                    November 23, 2015,  8:08pm
              10
              Thx but I just tried to activate the pru in the device tree with:
pru{
status:“okay”
              William,
Have you seen this… when I enable the PRU with a device tree overlay, I get this if I type top : (something to do with the interrupts taking up tons of CPU)
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
678 root 20 0 72872 21368 6372 S 11.2 4.2 0:03.56 node
687 root 20 0 11324 2252 1552 R 6.2 0.4 0:00.43 systemd-udevd
691 root 20 0 11324 1644 948 R 6.2 0.3 0:00.42 systemd-udevd
692 root 20 0 11324 1644 948 R 6.2 0.3 0:00.41 systemd-udevd
685 root 20 0 11324 2312 1612 R 5.9 0.5 0:00.43 systemd-udevd
686 root 20 0 11324 2252 1552 R 5.9 0.4 0:00.43 systemd-udevd
689 root 20 0 11324 2188 1488 R 5.9 0.4 0:00.43 systemd-udevd
690 root 20 0 11324 2188 1488 R 5.9 0.4 0:00.42 systemd-udevd
693 root 20 0 11324 1644 948 R 5.9 0.3 0:00.41 systemd-udevd
680 root 20 0 8076 3524 3040 S 3.6 0.7 0:00.23 laserlux
3 root 20 0 0 0 0 R 2.6 0.0 0:00.37 ksoftirqd/0
103 root 20 0 0 0 0 S 0.3 0.0 0:00.04 usb-storage
696 root 20 0 2980 1644 1288 R 0.3 0.3 0:00.06 top
1 root 20 0 21836 3204 2120 S 0.0 0.6 0:06.05 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
4 root 20 0 0 0 0 S 0.0 0.0 0:00.02 kworker/0:0
5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H
6 root 20 0 0 0 0 S 0.0 0.0 0:00.33 kworker/u2:0
7 root rt 0 0 0 0 S 0.0 0.0 0:00.00 watchdog/0
8 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 khelper
9 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kdevtmpfs
10 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 netns
11 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kswork
12 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 perf
13 root 20 0 0 0 0 S 0.0 0.0 0:00.04 kworker/0:1
14 root 20 0 0 0 0 S 0.0 0.0 0:00.00 khungtaskd
15 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 writeback
16 root 25 5 0 0 0 S 0.0 0.0 0:00.00 ksmd
17 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 crypto
18 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kintegrityd
19 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 bioset
20 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kblockd
Then after a couple minutes, those processes disappear and this appears in /var/log/syslog
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [679] /devices/platform/ocp/4a300000.pruss/uio/uio0 timeout; kill it
Nov 24 13:15:15 beaglebone rsyslogd-2007: action ‘action 17’ suspended, next retry is Tue Nov 24 13:15:45 2015 [try http://www.rsyslog.com/e/2007  ]
Nov 24 13:15:15 beaglebone systemd-udevd[172]: seq 2030 ‘/devices/platform/ocp/4a300000.pruss/uio/uio0’ killed
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [680] /devices/platform/ocp/4a300000.pruss/uio/uio1 timeout; kill it
Nov 24 13:15:15 beaglebone systemd-udevd[172]: seq 2036 ‘/devices/platform/ocp/4a300000.pruss/uio/uio1’ killed
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [681] /devices/platform/ocp/4a300000.pruss/uio/uio2 timeout; kill it
Nov 24 13:15:15 beaglebone systemd-udevd[172]: seq 2037 ‘/devices/platform/ocp/4a300000.pruss/uio/uio2’ killed
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [683] /devices/platform/ocp/4a300000.pruss/uio/uio3 timeout; kill it
Nov 24 13:15:15 beaglebone systemd-udevd[172]: seq 2038 ‘/devices/platform/ocp/4a300000.pruss/uio/uio3’ killed
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [684] /devices/platform/ocp/4a300000.pruss/uio/uio4 timeout; kill it
Nov 24 13:15:15 beaglebone systemd-udevd[172]: seq 2039 ‘/devices/platform/ocp/4a300000.pruss/uio/uio4’ killed
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [685] /devices/platform/ocp/4a300000.pruss/uio/uio5 timeout; kill it
Nov 24 13:15:15 beaglebone systemd-udevd[172]: seq 2040 ‘/devices/platform/ocp/4a300000.pruss/uio/uio5’ killed
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [686] /devices/platform/ocp/4a300000.pruss/uio/uio6 timeout; kill it
Nov 24 13:15:15 beaglebone systemd-udevd[172]: seq 2041 ‘/devices/platform/ocp/4a300000.pruss/uio/uio6’ killed
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [687] /devices/platform/ocp/4a300000.pruss/uio/uio7 timeout; kill it
Nov 24 13:15:15 beaglebone systemd-udevd[172]: seq 2042 ‘/devices/platform/ocp/4a300000.pruss/uio/uio7’ killed
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [681] terminated by signal 9 (Killed)
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [683] terminated by signal 9 (Killed)
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [679] terminated by signal 9 (Killed)
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [680] terminated by signal 9 (Killed)
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [684] terminated by signal 9 (Killed)
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [685] terminated by signal 9 (Killed)
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [686] terminated by signal 9 (Killed)
Nov 24 13:15:15 beaglebone systemd-udevd[172]: worker [687] terminated by signal 9 (Killed)
Nov 24 13:16:10 beaglebone systemd-timesyncd[209]: interval/delta/delay/jitter/drift 256s/-0.005s/0.075s/0.261s/-34ppm
Nov 24 13:16:10 beaglebone rsyslogd-2007: action ‘action 17’ suspended, next retry is Tue Nov 24 13:16:40 2015 [try http://www.rsyslog.com/e/2007  ]
Nov 24 13:16:56 beaglebone rsyslogd-2007: action ‘action 17’ suspended, next retry is Tue Nov 24 13:17:26 2015 [try http://www.rsyslog.com/e/2007  ]
Nov 24 13:17:01 beaglebone CRON[1650]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
What’s odd is my program continues to operate normally, and is using both PRU0 and PRU1 interrupts…
Erik
William,
No I haven’t, since I have not been looking. Perhaps the interrupts can be disabled ? I’ll have to look into it, but I do not really have any code / binaries built to use both PRUs. What are you doing exactly ?
              Just tell me in high level terms what your program loop does.
              You’re not firing an interrupt every program loop are you ?
              Those systemd-udevd entries appear as soon as the pru is enabled with the device tree overlay… totally independant of my program that later utilizes the PRU.
Erik
              Which file system are you using ? Whats the output of . . .
$ cat /etc/dogtag
BeagleBoard.org  Debian Image 2015-03-01
So keep this in mind. My base debian rootsfs is Wheezy 7.8. I also disable systemd through uEnv.txt. So I use SYSV versus systemd as an init daemon.
              I’m not 100% sure if the above mentioned items can play a role on your error messages. It is simply a guess. I would not think the kernel / kernel modules should be a problem here. But I suppose they could be. However, with that said.
$ cat /var/log/syslog
Nov 24 06:25:11 beaglebone rsyslogd: [origin software=“rsyslogd” swVersion=“5.8.11” x-pid=“1984” x-info=“http://www.rsyslog.com ”] rsyslogd was HUPed
Nov 24 07:17:01 beaglebone /USR/SBIN/CRON[3560]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Nov 24 08:17:01 beaglebone /USR/SBIN/CRON[3573]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Nov 24 09:17:01 beaglebone /USR/SBIN/CRON[3586]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Nov 24 10:17:01 beaglebone /USR/SBIN/CRON[3599]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Nov 24 11:17:01 beaglebone /USR/SBIN/CRON[3613]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Nov 24 12:17:01 beaglebone /USR/SBIN/CRON[3626]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Nov 24 13:17:01 beaglebone /USR/SBIN/CRON[3637]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Nov 24 14:17:01 beaglebone /USR/SBIN/CRON[3645]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Nov 24 15:17:01 beaglebone /USR/SBIN/CRON[3652]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
So, can you give me an order of things you’ve done in order to get you error messages, and I’ll try to duplicate them. Short of installing more stuff on my rootfs, which is already large enough as it is . . .
              Ok, I just realized what you said in your last post about systemd messages. So, from here, I’ll assume this has to be related to systemd. heh I completely missed that . . .
