Hi!
I had a Beagle Bone Black Wireless lying idle since a very long time. Today I am trying to boot the board and I am unable to access it.
I am trying to boot via SD card with this image flashed via Balena Etcher.
When I boot it up via the micro USB port the PWR
led lights up along with the USR0
led and USR1
LED faintly. I am using Windows 11 (sadly) and windows gives the hardware plugin sound and disconnect sound repeatedly. I even tried holding the Boot select switch S2
I tried attaching the USB to Serial adapter and I am getting the following output.
U-Boot SPL 2019.04-00002-g07d5700e21 (Mar 06 2020 - 11:24:55 -0600)
Trying to boot from MMC2
Loading Environment from EXT4... Card did not respond to voltage select!
U-Boot 2019.04-00002-g07d5700e21 (Mar 06 2020 - 11:24:55 -0600), Build: jenkins-github_Bootloader-Builder-137
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: BeagleBoard.org BeagleBone Black Wireless:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
Could not get PHY for cpsw: addr 0
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[BBBW] ...
switch to partitions #0, OK
btrfs_read_superblock: invalid checksum at superblock mirror 0
btrfs_read_superblock: invalid checksum at superblock mirror 1
btrfs_read_superblock: No valid BTRFS superblock found!
** Unrecognized filesystem type **
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
** Invalid partition 2 **
** Invalid partition 3 **
** Invalid partition 4 **
** Invalid partition 5 **
** Invalid partition 6 **
** Invalid partition 7 **
starting USB...
USB0: Port not available.
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC f4:5e:ab:68:72:17
HOST MAC de:ad:be:af:00:00
RNDIS ready
musb-hdrc: peripheral reset irq lost!
high speed config #2: 2 mA, Ethernet Gadget, using RNDIS
The remote end did not respond in time.missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/01-f4-5e-ab-68-72-17
RNDIS ready
The remote end did not respond in time.Retrieving file: pxelinux.cfg/C0A80102
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
The remote end did not respond in time.Retrieving file: pxelinux.cfg/default-arm-am33xx
RNDIS ready
RNDIS ready
RNDIS ready
The remote end did not respond in time.Config file not found
starting USB...
RNDIS ready
The remote end did not respond in time.using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
RNDIS ready
The remote end did not respond in time.=> <
I2C: ready
DRAM: 512 MiB
BeagleBone Black:
Net: eth0: MII MODE
cpsw, usb_ether
starting USB...
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
RNDIS ready
starting USB...
RNDIS ready
RNDIS ready
Can you please help me solve this issue?
