I have flashed this image into the SD card : bbai64-debian-11.8-minimal-arm64-2023-10-07-4gb.img.xz
The boot is rewinding non stop, I have tried other images, it’s either the same issue or get stuck in some fixedregulator-sd probing.
I also tried using a different SD card, different images, but same issue.
U-Boot SPL 2021.01-gea96725b (Sep 02 2023 - 15:57:35 +0000)
Model: BeagleBoard.org BeagleBone AI-64 R5
Board: BBONEAI-64-B0- rev B0
SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE: BL31: v2.9(release):v2.9.0
NOTICE: BL31: Built : 15:57:35, Sep 2 2023
I/TC:
I/TC: OP-TEE version: 3.22.0 (gcc version 10.2.1 20210110 (Debian 10.2.1-6)) #1 Sat Sep 2 15:57:4
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelinel
I/TC: Primary CPU initializing
I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.6.3--v08.06.03 (Chill Capybar')
I/TC: HUK Initialized
I/TC: Activated SA2UL device
I/TC: Fixing SA2UL firewall owner for GP device
I/TC: Enabled firewalls for SA2UL TRNG device
I/TC: SA2UL TRNG initialized
I/TC: SA2UL Drivers initialized
I/TC: Primary CPU switching to normal world boot
Model: Texas Instruments K3 J721E SoC
U-Boot 2021.01-gea96725b (Sep 02 2023 - 15:57:35 +0000)
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00
Net: eth0: ethernet@46000000port@1
Press SPACE to abort autoboot in 2 seconds
board_name=[BBONEAI-64-B0-] ...
name_fdt=[k3-j721e-beagleboneai64.dtb] ...
i2c_write: error waiting for data ACK (status=0x116)
pca953x gpio@22: Error reading output register
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
705 bytes read in 8 ms (85.9 KiB/s)
BeagleBone AI-64 microSD (extlinux.conf) Options
1: BeagleBone AI-64 microSD Recovery
2: BeagleBone AI-64 copy microSD to eMMC
3: BeagleBone AI-64 microSD (default)
Enter choice: 3: BeagleBone AI-64 microSD (default)
Retrieving file: /initrd.img
9150156 bytes read in 392 ms (22.3 MiB/s)
Retrieving file: /Image
29616640 bytes read in 1248 ms (22.6 MiB/s)
append: root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 quiet
Retrieving file: /k3-j721e-beagleboneai64.dtb
226922 bytes read in 18 ms (12 MiB/s)
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8f746000, end 8ffffecc ... OK
Loading Device Tree to 000000008f70b000, end 000000008f745669 ... OK
Starting kernel ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Reserved shared memory is enabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
[ 0.599549] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.599798] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.599936] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.600056] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.600201] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 1.122734] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@9
U-Boot SPL 2021.01-gea96725b (Feb 16 2023 - 17:13:47 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
Trying to boot from MMC1
init_env from device 17 not supported!
NOTICE: BL31: v2.5(release):0588523
NOTICE: BL31: Built : 17:13:47, Feb 16 2023
U-Boot 2021.01-gea96725b (Feb 16 2023 - 17:13:47 +0000)
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Scanning mmc 1:1...
9150156 bytes read in 393 ms (22.2 MiB/s)
Starting kernel ...
[ 0.591580] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.591814] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.591947] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.592070] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.592204] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 1.100936] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@9
[ 3.013033] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 3.020282] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 3.028811] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 3.036151] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 3.043458] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 3.050771] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Scanning mmc 1:1...
Starting kernel ...
[ 0.589441] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.589650] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.589771] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.589897] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.590042] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 1.089258] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@9
[ 3.013165] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 3.020402] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 3.028944] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 3.036267] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 3.043587] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 3.050898] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Scanning mmc 1:1...
705 bytes read in 9 ms (76.2 KiB/s)
Enter choice: 3
29616640 bytes read in 1249 ms (22.6 MiB/s)
Starting kernel ...
[ 0.594828] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.595063] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.595193] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.595319] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.595476] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 1.100979] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@9
[ 2.621137] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 3.020416] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 3.028949] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 3.036282] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 3.043594] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 3.050909] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 3.593135] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Scanning mmc 1:1...
Starting kernel ...
[ 0.592177] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.592390] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.592533] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.592659] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.592791] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 1.104695] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@9
[ 3.013096] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 3.020351] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 3.028877] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 3.036215] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 3.043528] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 3.050845] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[ 3.058819] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Scanning mmc 1:1...
705 bytes read in 7 ms (97.7 KiB/s)
9150156 bytes read in 391 ms (22.3 MiB/s)
29616640 bytes read in 1247 ms (22.6 MiB/s)
226922 bytes read in 17 ms (12.7 MiB/s)
Starting kernel ...
[ 0.590096] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.590299] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.590436] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.590556] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.590726] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 1.089433] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@9
[ 3.012961] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 3.020236] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 3.028760] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 3.036087] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 3.043403] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 3.050708] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Scanning mmc 1:1...
226922 bytes read in 19 ms (11.4 MiB/s)
Starting kernel ...
[ 0.598178] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.598381] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.598539] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.598652] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.598804] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 1.101443] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@9
[ 2.621551] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 3.013627] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 3.020874] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 3.029399] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[ 3.036735] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[ 3.044042] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[ 3.051357] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
SoC: J721E SR1.1 GP
DRAM: 4 GiB
Flash: 0 Bytes
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Scanning mmc 1:1...
Starting kernel ...
[ 0.590938] debugfs: Directory '31010000.pat' with parent 'regmap' already present!
[ 0.591142] debugfs: Directory '31011000.pat' with parent 'regmap' already present!
[ 0.591300] debugfs: Directory '31012000.pat' with parent 'regmap' already present!
[ 0.591424] debugfs: Directory '31013000.pat' with parent 'regmap' already present!
[ 0.591577] debugfs: Directory '31014000.pat' with parent 'regmap' already present!
[ 1.092788] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@9
[ 2.204717] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 3.012760] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[ 3.020019] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[ 3.028532] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
