Hello all. I’m having this problem and I’ve been banging my head against the wall for some time now. I’m running 64bit ubuntu 13.10 inside virtualbox vm. I’ve set up the NFS server and from what I can tell it’s configured properly because I’m able to mount it from another computer (laptop running ubuntu 12.04). I’m exporting /home/miro/export where I have a rootfs folder and a symbolic link to the kerel image (uImage-BBB-3.8.13)
NFS server is on 192.168.1.250, statically assigned ip
Beagle is on 192.168.1.115 assinged by DHCP. Beagleboard is running latest stock software.
I can ping server from beagle, but I’m not able to get past tftp 0x80200000 uImage-BBB-3.8.13
All devices are plugged into the same router. Also, I’m unsure about some of the env variables, such as rootpath.
If anyone could shed some light on this I would greatly appreciate it.
U-Boot# tftp 0x80200000 uImage-BBB-3.8.13
link up on port 0, speed 100, full duplex
Using cpsw device
TFTP from server 192.168.1.250; our IP address is 192.168.1.115
Filename ‘uImage-BBB-3.8.13’.
Load address: 0x80200000
Loading: T T T T T T T T T T T T T T T T T T T T
Retry count exceeded; starting again
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC 90:59:af:5d:07:b0
HOST MAC de:ad:be:af:00:00
RNDIS ready
ERROR: The remote end did not respond in time.
at ether.c:2395/usb_eth_init()
Using cpsw device
RNDIS ready
Using cpsw device
Abort
U-Boot# printenv
arch=arm
autoload=no
baudrate=115200
board=am335x
board_name=A335BNLT
board_rev=0A5C
bootcmd=gpio set 53; i2c mw 0x24 1 0x3e; run findfdt; mmc dev 0; if mmc rescan ; then echo micro SD card found;setenv mmcdev 0;else echo No micro SD card found, setting mmcdev to 1;setenv mmcdev 1;fi;setenv bootpart ${mmcdev}:2;mmc dev ${mmcdev}; if mmc rescan; then gpio set 54; echo SD/MMC found on device ${mmcdev};if run loadbootenv; then echo Loaded environment from ${bootenv};run importbootenv;fi;if test -n $uenvcmd; then echo Running uenvcmd …;run uenvcmd;fi;gpio set 55; if run loaduimage; then gpio set 56; run loadfdt;run mmcboot;fi;fi;
bootdelay=1
bootdir=/boot
bootenv=uEnv.txt
bootfile=uImage-BBB-3.8.13
bootpart=0:2
console=ttyO0,115200n8
cpu=armv7
dfu_alt_info_emmc=rawemmc mmc 0 3751936
dfu_alt_info_mmc=boot part 0 1;rootfs part 0 2;MLO fat 0 1;MLO.raw mmc 100 100;u-boot.img.raw mmc 300 3C0;u-boot.img fat 0 1;uEnv.txt fat 0 1
dfu_alt_info_nand=SPL part 0 1;SPL.backup1 part 0 2;SPL.backup2 part 0 3;SPL.backup3 part 0 4;u-boot part 0 5;kernel part 0 7;rootfs part 0 8
dnsip=192.168.1.1
ethact=cpsw
ethaddr=90:59:af:5d:07:b0
fdt_high=0xffffffff
fdtaddr=0x80F80000
fdtfile=am335x-boneblack.dtb
findfdt=if test $board_name = A33515BB; then setenv fdtfile am335x-evm.dtb; fi; if test $board_name = A335X_SK; then setenv fdtfile am335x-evmsk.dtb; fi;if test $board_name = A335BONE; then setenv fdtfile am335x-bone.dtb; fi; if test $board_name = A335BNLT; then setenv fdtfile am335x-boneblack.dtb; fi
gatewayip=192.168.1.1
importbootenv=echo Importing environment from mmc …; env import -t $loadaddr $filesize
ipaddr=192.168.1.115
kloadaddr=0x80007fc0
loadaddr=0x80200000
loadbootenv=load mmc ${mmcdev} ${loadaddr} ${bootenv}
loadfdt=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}
loadramdisk=load mmc ${mmcdev} ${rdaddr} ramdisk.gz
loaduimage=load mmc ${bootpart} ${kloadaddr} ${bootdir}/${bootfile}
mmcargs=setenv bootargs console=${console} ${optargs} root=${mmcroot} rootfstype=${mmcrootfstype}
mmcboot=echo Booting from mmc …; run mmcargs; bootm ${kloadaddr} - ${fdtaddr}
mmcdev=0
mmcroot=/dev/mmcblk0p2 ro
mmcrootfstype=ext4 rootwait
mtdids=nand0=omap2-nand.0
mtdparts=mtdparts=omap2-nand.0:128k(SPL),128k(SPL.backup1),128k(SPL.backup2),128k(SPL.backup3),1920k(u-boot),128k(u-boot-env),5m(kernel),-(rootfs)
nandargs=setenv bootargs console=${console} ${optargs} root=${nandroot} rootfstype=${nandrootfstype}
nandboot=echo Booting from nand …; run nandargs; nand read ${loadaddr} ${nandsrcaddr} ${nandimgsize}; bootm ${loadaddr}
nandimgsize=0x500000
nandroot=ubi0:rootfs rw ubi.mtd=7,2048
nandrootfstype=ubifs rootwait=1
nandsrcaddr=0x280000
netargs=setenv bootargs console=${console} ${optargs} root=/dev/nfs nfsroot=${serverip}:${rootpath},${nfsopts} rw ip=dhcp
netboot=echo Booting from network …; setenv autoload no; dhcp; tftp ${loadaddr} ${bootfile}; tftp ${fdtaddr} ${fdtfile}; run netargs; bootm ${loadaddr} - ${fdtaddr}
netmask=255.255.255.0
nfsopts=nolock
ramargs=setenv bootargs console=${console} ${optargs} root=${ramroot} rootfstype=${ramrootfstype}
ramboot=echo Booting from ramdisk …; run ramargs; bootm ${loadaddr} ${rdaddr} ${fdtaddr}
ramroot=/dev/ram0 rw ramdisk_size=65536 initrd=${rdaddr},64M
ramrootfstype=ext2
rdaddr=0x81000000
rootpath=/home/miro/export
serverip=192.168.1.250
soc=am33xx
spiargs=setenv bootargs console=${console} ${optargs} root=${spiroot} rootfstype=${spirootfstype}
spiboot=echo Booting from spi …; run spiargs; sf probe ${spibusno}:0; sf read ${loadaddr} ${spisrcaddr} ${spiimgsize}; bootm ${loadaddr}
spibusno=0
spiimgsize=0x362000
spiroot=/dev/mtdblock4 rw
spirootfstype=jffs2
spisrcaddr=0xe0000
static_ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off
stderr=serial
stdin=serial
stdout=serial
usbnet_devaddr=90:59:af:5d:07:b0
vendor=ti
ver=U-Boot 2013.04-dirty (Jun 19 2013 - 09:57:14)
