Hi
I am new to the BB AI. I have been facing some issues with the SD-card boot.
The board boots just fine off of the eMMC. However, I would like to boot it from the SD card.
I have used a number of images from the BB images page, written them into the SD card with Balena etcher, no use - the board always boots off of the eMMC.
I then tried formatting the card with FAT32 , allocation unit size 4096, and then checked if I could at least mount it from the eMMC booted system. The SD card is never recognized and there is no entry in /dev for this device.
I tried using dtc on the am5729-beagleboardai.dtb to generate the dts, followed the post at:
https://www.element14.com/community/thread/74281/l/beaglebone-ai-booting-from-sd-card-issue
specifically, I did this:
"converted the am5729-beagleboneai.dtb to xx.dts using “dtc”. Then, I found out mmc1 node (mmc@4809c000), and modify some places as follows:
1. compatible = “ti,dra7-sdhci”; >>>>> compatible = “ti,dra7-sdhci”, “ti,omap4-hsmmc”;
2. add: vmmc_aux-supply = <0xd0>; (same node with vqmmc-supply)
3. max-frequency = <0xb71b000>; >>>>> max-frequency = <0x16e3600>; (to lower the frequency of mmc)
Save and exit, then convert the .dts file to am5729-beagleboneai.dtb, replace the old one.
(copied the steps from the above site)
This does not work either.
I dont have a serial interface for the board just yet so I dont have the serial output.
I would appreciate any input or help. I am not sure what I should do to get this board booting off of the SD card.
Thank you and Best regards!
