Hi all together,
first of all, excuse my english, it’s not my fathers language.
Since I received my first 2 BBB I try to boot BBB from SD-Cards.
I plan to use Starterware from TI, so I loaded Starterware and CCS 5.4 an installed it on Windows 7 Computer.
In the dir “AM335X\binary\armv7a\ct_css\am335x\beaglebone\bootloader” I found “MLO” and in
“AM335X\binary\armv7a\ct_css\am335x\beaglebone\demo” I found “app”.
I loadet the tool “HP USB Disk Storage Format Tool” and format the SD.
After that I copied the 2 files with Drag & Drop to the SD-Card.
After inserting the Card to BBB and connecting terminal to J1 (RS232) the terminal reports:
U-Boot SPL 2013.04-dirty (Jun 19 2013 - 09:57:14)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (Jun 19 2013 - 09:57:14)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
** Unable to read file uEnv.txt **
** Invalid partition 2 **
U-Boot#
My next step was to hold down S2 while powering BBB.
Result: Exact the same.
Next step: Loading “TI_SDCard_boot_utility_v1_9.exe” and execute it.
With this newly formatted Cart I tried to boot BBB again.
So, now I’m at a point needing your help, I have no idea what I have to do.
BTW Angström is correct booting, no problems.
Thank you all
Matthias
