Hello all,
I wanted to put Ubuntu on my beagleboard Rev C,
and I followed the instructions here:
https://eewiki.net/display/linuxonarm/BeagleBoard.
I’m doing all this with a desktop running Ubuntu 14.04,
on which I cross compile the kernel.
The instructions are quite good, and everything seemed was going as expected.
I successfully compiled the 4.6 kernel without any errors.
In the ‘prepare SD card section’,
(https://eewiki.net/display/linuxonarm/BeagleBoard#BeagleBoard-SetupmicroSDcard)
however, i noticed that the command given creates a /rootfs partition of just 1MB.
The boot partition is 12MB, which seems ok.
Naturally /rootfs was too small, so I created another 4GB ext4 partition, using that instead of the original
1MB partition. To account for this I changed the fstab, to mount the new rootfs (mmcblkp3) on /.
Then, pressing down the user button, I powered up the Beagleboard.
I get messages on the serial port, the last of which is “starting kernel…” - and nothing more.
The full bootup message log is here: http://pastebin.com/raw/x1izWrk
The log shows:
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.6.1-armv7-x4 …
which means the rootfs partition is being read properly,
but how do I know the correct partition is being mounted?
Also, I am puzzled by the total lack of messages after the last message,
i.e. “Starting kernel”
