Hey there Beaglebone community,
I am trying to connect two microchip MCP2515 CAN controller over SPI to a beaglebone, one on SPI0 and another one on SPI1. I followed this procedure: https://gist.github.com/pdp7/20dddbeffe83082e3c94ab0903563783 and make it work for SPI0. Now, I am trying to compile a new dts for SPI1. This is my source:
/dts-v1/;
/plugin/;
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/pinctrl/am33xx.h>
#include <dt-bindings/interrupt-controller/irq.h>
compatible = "ti,beaglebone", "ti,beaglebone-black", "ti,beaglebone-green";
exclusive-use = "P8.5", "gpio1_2";
fragment@0 {
target = <&spi1>;
__overlay__ {
status = "okay";
spidev@1 {
status = "disabled";
fragment@1 {
target = <&am33xx_pinmux>;
__overlay__ {
mcp2515-dev1_int: mcp2515_int {
pinctrl-single,pins = < 0x008 0x37 >;
fragment@2 {
target-path = "/";
__overlay__ {
mcp2515-dev1_clock: mcp2515_clock {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <8000000>;
fragment@3 {
target = <&spi1>;
__overlay__ {
#address-cells = <1>;
#size-cells = <0>;
can1: mcp2515@1 {
status = "okay";
reg = <0>;
compatible = "microchip,mcp2515";
pinctrl-names = "default";
pinctrl-0 = <&mcp2515-dev1_int>;
spi-max-frequency = <10000000>;
interrupt-parent = <&gpio1>;
interrupts = <3 2>;
clocks = <&mcp2515-dev1_clock>;
mcp251x,oscillator-frequency = <8000000>;
mcp251x,irq-gpios = <&gpio1 2 0>;
mcp251x,stay-awake = <1>;
mcp251x,enable-clkout = <1>;
__overrides__ {
oscillator = <&mcp2515-dev1_clock>,"clock-frequency:0";
spimaxfrequency = <&can1>,"spi-max-frequency:0";
interrupt = <&mcp2515-dev1_int>,"pinctrl-single,pins:0",<&can1>,"interrupts:0";
After trying to compile:
dtc -@ -Hepapr -I dts -O dtb -o MCP2515-dev1.dtbo MCP2515-dev1.dts
or
dtc -O dtb -o MCP2515-dev1.dtbo -b 0 -@ MCP2515-dev1.dts
or by placing the dts under /opt/source/bb.org-overlays/src/arm and running install.sh under /opt/source/bb.org-overlays
I get the same error:
DTC src/arm/MCP2515-dev1.dtbo
Error: src/arm/MCP2515-dev1.dts:26.20-21 syntax error
FATAL ERROR: Unable to parse input tree
What am I doing wrong? Does the dts seems correct for my purposes?
/opt/scripts/tools/version.sh output:
git:/opt/scripts/:[b39ec679648a6be8f25f48bd1c9784c1fc5a0c46]
eeprom:[A335BNLTEIA02118SBB08756]
dogtag:[BeagleBoard.org Debian Buster IoT Image 2020-04-06]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2019.04-00002-g07d5700e21]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2019.04-00002-g31a8ae0206]:[location: dd MBR]
version.sh: line 137: warning: command substitution: ignored null byte in input
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts]
UBOOT: Loaded Overlay:[AM335X-PRU-RPROC-4-19-TI-00A0]
UBOOT: Loaded Overlay:[BB-ADC-00A0]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0]
UBOOT: Loaded Overlay:[BB-HDMI-TDA998x-00A0]
kernel:[4.19.94-ti-r42]
nodejs:[v10.15.2]
/boot/uEnv.txt Settings:
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.14.20200403.0-0rcnee0~buster+20200403]
pkg:[bb-wl18xx-firmware]:[1.20200322.0-0rcnee0~buster+20200322]
pkg:[kmod]:[26-1]
pkg:[librobotcontrol]:[1.0.4-git20190227.1-0rcnee0~buster+20190327]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~buster+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal bluetooth netdev i2c gpio pwm eqep remoteproc admin spi iio docker tisdk weston-launch xenomai cloud9ide]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 57.731246] remoteproc remoteproc0: wkup_m3 is available
[ 57.828145] remoteproc remoteproc0: powering up wkup_m3
[ 57.828174] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[ 57.828428] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 60.180227] remoteproc remoteproc1: 4a334000.pru is available
[ 60.194163] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
[ 60.180390] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[ 60.194341] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
dmesg | grep pinctrl-single
[ 0.921363] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
[ 0.934637] gpio-of-helper ocp:cape-universal: ready
lsusb
END
