I have BBB connected via USB, using PuTTY on windows
When I type -
ping 192.168.7.1 → 20 packets sent, 0 received, 100% loss
Always packets are sent but received is zero always
Can anyone debug this problem?
Ps - I see this step in Derek Molloy’s Beaglebone- Getting Started - Windows USB Network Adapter Setup Tutorial. Cant go ahead, I am stuck
Try 192.168.7.2
Molloy changed the default
I didnt understand what you meant. To explain more from my side -
In PuTTY,
Host Name (or IP address) : 192.168.7.2
Port : 22
When I load session with above settings,
then if we want to connect back to the PC,
ping 192.168.7.1
So the PC appears as 192.168.7.1 on network and BBB is 192.168.7.2
But when I try myself, zero packets are received
Hello pariyan,
stuck with the same problem
did you find the solution, if found please help me
same to me…i cant ping my laptop(192.168.7.1) from putty (beaglebone black connected to my laptop via usb)
