Hi everyone,
I am not able to enable any GPIO pins and then toggle them using (for eg: config-pin P8.7 gpio) command.
debian@beaglebone:~$ config-pin P8.7 gpio
P8_07 pinmux file not found!
Pin has no cape: P8_07
Actually in uEnv.txt i have disabled uboot-overlays because when i enable it i am not able to play audio.when i disable it i am able to play audio.
###Master Enable
#enable_uboot_overlays=1
###Cape Universal Enable
enable_uboot_cape_universal=1
(i enabled cape-universal also but as uboot-overlay is disabled cape-universal is also not working i guess)
cape_enable=bone_capemgr.enable_partno=BB-UART2,BB-UART4,BB-BONE-AUDI-02
(this is to enable audio)
So i just want to know is there any other way to enable GPIO other than uboot-overlay(cape-universal) as i cant compromise on audio. Audio is must for my project. I have tried multiple ways for audio.only this method worked. So i want alternative way for enabling GPIO.
Please help ASAP.
Thanks in advance.
Jithu
Hi everyone,
###Master Enable
Please help ASAP.
This was fixed within the last couple of weeks…
Run
So we can find out what your running.
Hi Robert,
Thanks alot for replying. Ok but when i searched i couldnt find a solution. It will be really helpful if u will look into this. Here is the version.sh log which u asked for.
debian@beaglebone:~$ sudo /opt/scripts/tools/version.sh
[sudo] password for debian:
git:/opt/scripts/:[4dd50b306e4eb31a05bb72a9573febc3695f1f05]
eeprom:[A335BNLT00C04717BBBK0E43]
dogtag:[BeagleBoard.org Debian Image 2017-03-19]
bootloader:[/dev/mmcblk0]:[U-Boot 2017.03-00002-gd12b1519b4]
kernel:[4.4.54-ti-r93]
nodejs:[v6.14.3]
device-tree-override:[dtb=ibot_controls.dtb]
The dtb file is the one which i compiled for some extra features.
Jithu
Hi Robert,
too old, you'd need 2018.03
wrong branch, you'll need v4.14.x-ti (4.14.65-ti-r72)
nodejs:[v6.14.3]
this disables the config-pin path in v4.14.x-ti.. (4.14.65-ti-r72)
This would get you that:
debian@test-bbb-2:~$ cd /opt/scripts/tools/
debian@test-bbb-2:/opt/scripts/tools$ git pull
Already up-to-date.
debian@test-bbb-2:/opt/scripts/tools$ sudo ./update_kernel.sh
--ti-channel --lts-4_14
debian@test-bbb-2:/opt/scripts/tools$ sudo ./developers/update_bootloader.sh
debian@test-bbb-2:/opt/scripts/tools$ sudo apt install --only-upgrade
bb-cape-overlays
Just remember, to disable dtb=ibot_controls.dtb in /boot/uEnv.txt
and have:
enabled...
