Unable to enable SPI1 on BeagleBone Black (Debian 12 Bookworm - Kernel 6.12)
Hello, I’m trying to enable SPI1 on a BeagleBone Black to flash a T400 BIOS, but I’ve hit a wall with the latest Debian 12 image.
System Details:
  • Image: BeagleBoard.org Debian Bookworm Base Image 2025-05-27
  • Kernel: 6.12.28-bone25
  • Hardware: BeagleBone Black Rev C
What I have tried so far:
  1. I installed the bb-cape-overlays package, but the /lib/firmware/ directory still doesn’t contain BB-SPIDEV1-00A0.dtbo. It seems the package doesn’t provide the expected binaries for this kernel version.
  2. I attempted to manually compile the .dts sources found in /opt/source/ using dtc, but it fails with syntax errors.
  3. I added enable_uboot_overlays=1 and uboot_overlay_addr4=/lib/firmware/BB-SPIDEV1-00A0.dtbo to uEnv.txt, but after rebooting, /dev/spidev1.0 is still missing.
  4. config-pin is not available on this image, and the pins remain in GPIO mode according to show-pins.
What is the correct way to enable SPIDEV1 on this specific 2025-05-27 Base Image? Are the compiled overlays stored in a different location or repository for the 6.12.x kernels?
First run…
sudo apt update
sudo apt-get dist-upgrade
Then reboot..
Next…
cd /opt/source/dtb-6.12.x/
make clean
git pull
./build_n_install.sh
Then set: uEnv.txt
uboot_overlay_addr4=BB-SPIDEV1-00A0.dtbo
Reboot..
Then verify with sudo beagle-version
Thank you, it worked. I’m so grateful!
