I am using the ubuntu image, i got from the following site. http://www.timzaman.nl/?p=1114&lang=en.
I am unable to connect to the net through the Beagle-xM Rev C board. I get the below error on trying to use sudo apt-get update.
My setup comprises of my laptop connected to a ADSL router, running ubuntu 10.04 LTS in VMWare. The board is connected to the router. I am able to ping the router’s ip. I am not able to ping the laptop through the board or the board through the laptop. Also the green and orange LED’s on the ethernet jack are glowing. The board is running Ubuntu 11.04 Natty.
ubuntu@omap:~$ sudo ifconfig -a
[sudo] password for ubuntu:
eth0 Link encap:Ethernet HWaddr 4a:5d:3e:1e:fb:b5
inet addr:192.168.1.6 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::485d:3eff:fe1e:fbb5/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1488 Metric:1
RX packets:12 errors:0 dropped:0 overruns:0 frame:0
TX packets:21 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1626 (1.6 KB) TX bytes:2790 (2.7 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
usb0 Link encap:Ethernet HWaddr 7e:55:fe:f4:67:67
BROADCAST MULTICAST MTU:1500 Metric:1
ubuntu@omap:~$ sudo dhclient eth0
ubuntu@omap:~$ sudo apt-get update
Err http://ports.ubuntu.com natty InRelease
Err http://ports.ubuntu.com natty-updates InRelease
Err http://ports.ubuntu.com natty Release.gpg
Temporary failure resolving 'ports.ubuntu.com’
Err http://ports.ubuntu.com natty-updates Release.gpg
Reading package lists… Done
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/natty/InRelease
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/natty-updates/InRelease
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/natty/Release.gpg Temporary failure resolving 'ports.ubuntu.com’
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/natty-updates/Release.gpg Temporary failure resolving 'ports.ubuntu.com’
W: Some index files failed to download. They have been ignored, or old ones used instead.
Can someone point me in the direction as to how to solve this problem?
Thanks & Regards,
Sanchayan.
