On Wed, 26 Dec 2018 15:16:53 -0800 (PST),
alekarasma@gmail.com declaimed the following:
Thank you Tarmo and Dennis for a reply. I have already connected
an ethernet cable and enabled sharing and I have as well tried
commnds mentioned by Tarmo but no luck.
I am getting 100% data loss for ping 8.8.8.8 and This is the output I get
after update.
If you can't ping Google's nameserver, you do NOT HAVE networking set
up.
Using USB with a host computer that does NOT have connection sharing
active:
debian@beaglebone:~$ ifconfig
eth0: flags=-28669<UP,BROADCAST,MULTICAST,DYNAMIC> mtu 1500
ether d0:39:72:18:3e:e5 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 53
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 1280 bytes 88000 (85.9 KiB)
TX packets 1280 bytes 88000 (85.9 KiB)
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.7.2 netmask 255.255.255.252 broadcast 192.168.7.3
inet6 fe80::d239:72ff:fe18:3ee7 prefixlen 64 scopeid 0x20<link>
ether d0:39:72:18:3e:e7 txqueuelen 1000 (Ethernet)
RX packets 845 bytes 76867 (75.0 KiB)
RX errors 0 dropped 4 overruns 0 frame 0
TX packets 88 bytes 20650 (20.1 KiB)
usb1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.6.2 netmask 255.255.255.252 broadcast 192.168.6.3
ether d0:39:72:18:3e:ea txqueuelen 1000 (Ethernet)
debian@beaglebone:~$ ping 8.8.8.8
connect: Network is unreachable
Connecting a CAT-5 to my network router, and rebooting -- still SSH
using USB (192.168.7.2) as I don't want to dig up the extension cord and
power supply (otherwise I'd be using SSH over my network and not via USB).
"""debian@beaglebone:~$ ifconfig
eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 192.168.1.69 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 2600:1700:e630:890:d239:72ff:fe18:3ee5 prefixlen 64 scopeid
0x0<global>
inet6 fe80::d239:72ff:fe18:3ee5 prefixlen 64 scopeid 0x20<link>
inet6 2600:1700:e630:890::44 prefixlen 64 scopeid 0x0<global>
RX packets 49 bytes 6158 (6.0 KiB)
TX packets 125 bytes 18827 (18.3 KiB)
device interrupt 53
RX packets 164 bytes 13240 (12.9 KiB)
TX packets 164 bytes 13240 (12.9 KiB)
RX packets 256 bytes 32650 (31.8 KiB)
TX packets 69 bytes 16126 (15.7 KiB)
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=121 time=22.7 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=121 time=22.3 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=121 time=21.6 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=121 time=21.8 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=121 time=20.9 ms
64 bytes from 8.8.8.8: icmp_seq=6 ttl=121 time=21.7 ms
^C
--- 8.8.8.8 ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 5007ms
rtt min/avg/max/mdev = 20.996/21.899/22.748/0.575 ms
Note the extra information shown for eth0
{I was going to put in a traceroute, but it seems that command is not
available in net-tools as documented on the web... found it in just
package traceroute}
debian@beaglebone:~$ sudo apt-get install traceroute
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
traceroute
0 upgraded, 1 newly installed, 0 to remove and 8 not upgraded.
Need to get 51.1 kB of archives.
After this operation, 124 kB of additional disk space will be used.
Get:1 Index of /debian stretch/main armhf traceroute armhf
1:2.1.0-2 [51.1 kB]
Fetched 51.1 kB in 1s (36.1 kB/s)
<SNIP>
debian@beaglebone:~$ traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 60 byte packets
1 dsldevice.attlocal.net (192.168.1.254) 0.830 ms 0.731 ms 0.398 ms
2 76.255.152.1 (76.255.152.1) 25.995 ms 27.292 ms 34.703 ms
3 71.152.176.29 (71.152.176.29) 18.978 ms 20.659 ms 20.582 ms
4 cr2.cgcil.ip.att.net (12.123.7.142) 29.214 ms 29.309 ms 32.375 ms
5 12.123.159.49 (12.123.159.49) 26.685 ms 26.877 ms 27.899 ms
6 12.247.252.10 (12.247.252.10) 28.592 ms 12.247.252.14 (12.247.252.14)
21.970 ms 12.247.252.6 (12.247.252.6) 22.450 ms
(that's enough of that... First node listed is my network router)
