Hello there
I bought a new BeagleBone Black Rev C from Amazon last week and I am unable to login using the default username and password. Following is the output from Minicom to help you understand my issue:
I have not connected any Ethernet cable and I also tried connecting an Ethernet cable but unfortunately the same problem persists.
Can someone help me debug this issue. Thank you !
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Feb 7 2016, 13:37:27.
Port /dev/ttyUSB0, 18:06:18
Press CTRL-A Z for help on special keys
U-Boot SPL 2015.10-00001-g143c9ee (Nov 06 2015 - 15:27:19)
bad magic
U-Boot 2015.10-00001-g143c9ee (Nov 06 2015 - 15:27:19 -0600), Build: jenkins-github_Bootloader-Builder-274
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Reset Source: Global external warm reset has occurred.
Using default environment
cpsw
switch to partitions #0, OK
mmc0 is current device
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
** Invalid partition 2 **
** Invalid partition 3 **
** Invalid partition 4 **
** Invalid partition 5 **
** Invalid partition 6 **
** Invalid partition 7 **
1800 bytes read in 15 ms (117.2 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-3.8.13-bone79 …
5644336 bytes read in 326 ms (16.5 MiB/s)
loading /boot/dtbs/3.8.13-bone79/am335x-boneblack.dtb …
26118 bytes read in 21 ms (1.2 MiB/s)
loading /boot/initrd.img-3.8.13-bone79 …
2862929 bytes read in 174 ms (15.7 MiB/s)
debug: [console=ttyO0,115200n8 root=UUID=e9dd472d-cc3d-45bd-85a9-633f3fd8ff0f ro rootfstype=ext4 rootwait coherent_pool=1M quiet init=/lib/systemd/systemd cape_.
debug: [bootz 0x82000000 0x88080000:2baf51 0x88000000] …
Kernel image @ 0x82000000 [ 0x000000 - 0x562030 ]
Loading Ramdisk to 8fd45000, end 8fffff51 … OK
Loading Device Tree to 8fd3b000, end 8fd44605 … OK
Starting kernel …
[ 0.372380] omap2_mbox_probe: platform not supported
[ 0.528145] tps65217-bl tps65217-bl: no platform data provided
[ 0.592204] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.629312] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.666420] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.703529] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.719264] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.728821] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 0.735548] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.752188] omap_hsmmc mmc.5: of_parse_phandle_with_args of ‘reset’ failed
[ 0.815138] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.8
[ 0.826792] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.834057] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
Loading, please wait…
systemd-fsck[216]: rootfs: clean, 97227/227584 files, 514831/909056 blocks
Debian GNU/Linux 7 beaglebone ttyO0
BeagleBoard.org Debian Image 2015-11-12
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
The IP Address for usb0 is: 192.168.7.2
beaglebone login: [ 26.200534] libphy: PHY 4a101000.mdio:01 not found
[ 26.205594] net eth0: phy 4a101000.mdio:01 not found on slave 1
