Probably you are missing to setup the gateway and DNS on your beaglebone. If your XP machine can connect to Internet and is on the same network as your beaglebone, then try to find the settings from the XP machine.
Is this a domestic router? It’s not common to have a public IP as the default route on a domestic router. You also shouldn’t have to set any routes manually on such a router as they’re added via DHCP.
What is the model of your router? Is it perhaps just a modem, how many network connectors does it have?
This part:
A few questions:
- Did you set your IP address manually or using DHCP?
- Can you show the output of “netstat -rn”?
- Can you show the output of “nm-tools”?
On your windows XP machine, what is the IP address, gateway and DNS server setting? It should be there in the LAN properties.
I did not set my IP address manually. I am using a computer connected to an organization’s network.
root@beaglebone:~# netstat -rn
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
0.0.0.0 148.179.243.254 0.0.0.0 UG 0 0 0 eth0
148.179.202.16 148.179.243.254 255.255.255.255 UGH 0 0 0 eth0
148.179.243.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
148.179.243.254 0.0.0.0 255.255.255.255 UH 0 0 0 eth0
151.110.50.27 148.179.243.254 255.255.255.255 UGH 0 0 0 eth0
151.110.50.28 148.179.243.254 255.255.255.255 UGH 0 0 0 eth0 -
root@beaglebone:~# nm-tools
-sh: nm-tools: command not found
Siddharth
Some thoughts:
On your Windows computer:1) Do “ipconfig /all” so we can see the values assigned to “DNS Servers”
On your BeagleBone
- Do “ifconfig -a” so we can see what your IP address info is for the Bone
- Do “cat /etc/resolv.conf” so we can see what DNS info you have there
- You mentioned that you can ping other intranet devices. Can you ping the default gateway address?
- Can you ping back and forth between the Windows computer and the BeagleBone?
- You mentioned that you are “in an organization”. Do they have any firewalls that prevent unknown devices from getting external access? Sometimes companies will have whitelists for known hosts and block all others.
- Results of ipconfig /all on windows
2) Results of 'ifconfig -a’ on beaglebone
- Doing cat /etc/resolv.conf gives following result
root@beaglebone:~# cat /etc/resolv.conf
Generated by Connection Manager
nameserver 127.0.0.1
Yes, I can ping the default gateway
root@beaglebone:~# ping 148.179.243.254
PING 148.179.243.254 (148.179.243.254) 56(84) bytes of data.
64 bytes from 148.179.243.254: icmp_req=1 ttl=255 time=0.671 ms
64 bytes from 148.179.243.254: icmp_req=2 ttl=255 time=0.427 ms
64 bytes from 148.179.243.254: icmp_req=3 ttl=255 time=0.610 ms
64 bytes from 148.179.243.254: icmp_req=4 ttl=255 time=0.489 ms
^C
— 148.179.243.254 ping statistics —
4 packets transmitted, 4 received, 0% packet loss, time 2999ms
rtt min/avg/max/mdev = 0.427/0.549/0.671/0.097 ms -
Yes, the firewall is setup.
Unless I missed a change somewhere in your email, your nameserver is the
loopback device and you will never resolve a hostname that way. You can
ping IP addresses, no problem. Set the nameserver to 8.8.8.8 and become
part of the google evil empire
Thanks Eric.
Pardon my naivety, but how do I set or rather change the nameserver to 8.8.8.8?
Thanks once again,
Siddharth
I searched on google, and I could find this:
To change the nameservers to Googles nameservers: 8.8.8.8, first find the name of the cable connection by doing this:
/usr/lib/connman/test/get-services
and suppose this name is : ethernet_0018318ddea3_cable, do this:
root@beaglebone:~# /usr/lib/connman/test/set-nameservers ethernet_0018318ddea3_cable 8.8.8.8
Is this how even I am supposed to proceed?
Siddharth
dnsmasq should be running and listening on localhost.
Below is the result that I am obtaining after changing the nameserver to 8.8.8.8 as suggested by Eric.
Getting the ethernet name:
root@beaglebone:~# /usr/lib/connman/test/get-services
[ /net/connman/service/ethernet_001831938d36_cable ]
IPv6.Configuration = { Method=auto Privacy=disabled }
AutoConnect = false
Name = Wired
Nameservers = [ 148.179.202.16 151.110.50.27 151.110.50.28 ]
Provider = { }
Favorite = true
Domains.Configuration = [ ]
State = ready
Proxy = { Method=direct }
Nameservers.Configuration = [ 148.179.202.16 151.110.50.27 151.110.50.28 ]
IPv4 = { Netmask=255.255.255.0 Gateway=148.179.243.254 Method=dhcp Address=1
48.179.243.101 }
IPv6 = { }
Domains = [ xxxxxxxxxx ]
Ethernet = { Interface=eth0 MTU=1500 Method=auto Address=00:18:31:93:8D:36 }
Security = [ ]
Proxy.Configuration = { }
Type = ethernet
Immutable = false
IPv4.Configuration = { Method=dhcp }
Changing the nameserver to 8.8.8.8
root@beaglebone:~# /usr/lib/connman/test/set-nameservers ethernet_001831938d36_c
able 8.8.8.8
Setting nameserver to [‘8.8.8.8’] -
Pinging google
root@beaglebone:~# ping google.com
PING google.com (74.125.225.137) 56(84) bytes of data.
^C
— google.com ping statistics —
5 packets transmitted, 0 received, 100% packet loss, time 4007ms -
Checking the changed nameserver:
This shows that the nameserver is not changed!
How to go about doing that?
Siddharth
Ah, I didn’t realize you were using connman for your network configuration. Changing the nameserver with connman doesn’t seem to change anything in the /etc/resolv.conf file, so no worries there. If your Nameservers [] field is updated when you execute “get-services”, you should be ok.
I checked the output of my “get-services” against yours and the only difference is that your “State = ready” and my “State = online”. From this link:
http://comments.gmane.org/gmane.linux.network.connman/10238
it appears that the transition to “online” only occurs when it is able to fetch the page indicated in the link. So if you don’t have internet connectivity (which your previous posts indicate you don’t), that would explain why your status hasn’t transitioned. Also, since you’re using DHCP, your server seemed to be serving you a couple perfectly good nameservers (presumably, since they’re the same ones that were handed to your XP box).
In a previous post you mentioned that your organization did have a firewall. You said you can ping your gateway (which is on the same subnet as your BeagleBone), but can you ping your DNS servers? Can you ping anything not on your immediate subnet? Is it possible that your organization’s routers are setup to block unknown hosts or ports? At this point your configuration does not immediately appear to be the issue, so I would investigate those next. At my last company ports were tied to specific MAC addresses, so rogue devices could DHCP an address, but could not actually reach any other machines. Just a thought.
Ah, I didn’t realize you were using connman for your network configuration. Changing the nameserver with connman doesn’t seem to change anything in the /etc/resolv.conf file, so no worries there. If your Nameservers field is updated when you execute “get-services”, you should be ok.
Thanks for replying Mike.
I tried pinging the nameservers. Is that what you meant by pinging DNS server?
[ /net/connman/service/ethernet_78c5e5b1079c_cable ]
AutoConnect = false
Name = Wired
Provider = { }
Favorite = true
State = ready
48.179.243.143 }
IPv6 = { }
Domains = [ napa.ad.etn.com ]
Ethernet = { Interface=eth0 MTU=1500 Method=auto Address=78:C5:E5:B1:07:9C }
Security =
Type = ethernet
Immutable = false
root@beaglebone:~# ping 148.179.202.16
PING 148.179.202.16 (148.179.202.16) 56(84) bytes of data.
64 bytes from 148.179.202.16: icmp_req=1 ttl=127 time=0.367 ms
64 bytes from 148.179.202.16: icmp_req=2 ttl=127 time=0.366 ms
64 bytes from 148.179.202.16: icmp_req=3 ttl=127 time=0.427 ms
^C
— 148.179.202.16 ping statistics —
3 packets transmitted, 3 received, 0% packet loss, time 1998ms
rtt min/avg/max/mdev = 0.366/0.386/0.427/0.036 ms
root@beaglebone:~# ping 151.110.50.27
PING 151.110.50.27 (151.110.50.27) 56(84) bytes of data.
64 bytes from 151.110.50.27: icmp_req=1 ttl=122 time=343 ms
64 bytes from 151.110.50.27: icmp_req=2 ttl=122 time=343 ms
64 bytes from 151.110.50.27: icmp_req=3 ttl=122 time=345 ms
^C
— 151.110.50.27 ping statistics —
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 343.293/343.984/345.031/0.752 ms
root@beaglebone:~# ping 151.110.50.28
PING 151.110.50.28 (151.110.50.28) 56(84) bytes of data.
64 bytes from 151.110.50.28: icmp_req=1 ttl=120 time=349 ms
64 bytes from 151.110.50.28: icmp_req=2 ttl=120 time=355 ms
64 bytes from 151.110.50.28: icmp_req=3 ttl=120 time=349 ms
^C
— 151.110.50.28 ping statistics —
rtt min/avg/max/mdev = 349.518/351.512/355.103/2.544 ms
This shows that I can ping my nameservers.
I can ping my company’s url. But I am assuming that is also on my immediate subnet.
Yes it might be possible. At this moment, I am not aware.
Thanks & Best Regards,
Siddharth Kabra
So you can ping hosts on your subnet, and you are being routed (through your default gateway) to hosts on other subnets (i.e. your nameservers), and you can even ping your own company’s URL, which would likely indicate that your nameservers are resolving that for you. But you can’t ping external hosts via hostname or direct IP (i.e. the Google IP I gave you to try before). This sounds like it’s not an issue with your BeagleBone config, but more likely a routing issue internal to your company. I would contact your IT folks to see if they can help you figure it out.
Thanks, I will do that and will let you know.
Hello All,
Thanks for all the help that was offered to me.
Finally, I could get the internet on beaglebone working! Now, I am able to ping any site outside the intranet. The problem was my company’s firewall, as rightly suggested by Mike. The firewall was blocking the access to internet.
Now, the next part of the problem is to transfer data from my laptop to the beaglebone.I have a laptop with windows 7 OS installed. I want to transfer data from the laptop to the beaglebone. For starting, I want to transfer any random number. Please help! It seems like another naive issue, but I would appreciate any help in this regard.
Please let me know if any details are required.
Siddharth
