Im trying to use mjpg-streamer on my Beaglebone Blue running Debian 8.7 (bone-debian-8.7-lxqt-4gb-armhf-2017-03-19-4gb.img.xz).
I am also using 2 C270 logitech webcams but am only trying to stream one at a time.
This is the tutorial I have been trying to follow to install MJPG-Streamer as it uses the BB-Black which is the closest tutorial I can find to the BB-Blue.
Here are the commands supplied by the tutorial.
sudo apt-get install g++ curl pkg-config libv4l-dev libjpeg-dev build-essential libssl-dev vim cmake
sudo apt-get install imagemagick
wget https://github.com/shrkey/mjpg-streamer/raw/master/mjpg-streamer.tar.gz
tar -xvf ./mjpg-streamer.tar.gz
cd mjpg-streamer
make
sudo make install
./mjpg_streamer -i “./input_uvc.so” -o “./output_http.so -w ./www”
This is my result fom running ./mjpg_streamer -i “./input_uvc.so” -o “./output_http.so -w ./www”:
debian@beaglebone:~/mjpg-streamer$ ./mjpg_streamer -i “./input_uvc.so” -o “./output_http.so -w ./www -p 8090”
MJPG Streamer Version: svn rev:
i: Using V4L2 device.: /dev/video0
i: Desired Resolution: 640 x 480
i: Frames Per Second.: 5
i: Format…: MJPEG
Adding control for Pan (relative)
UVCIOC_CTRL_ADD - Error: Inappropriate ioctl for device
Adding control for Tilt (relative)
Adding control for Pan Reset
Adding control for Tilt Reset
Adding control for Pan/tilt Reset
Adding control for Focus (absolute)
mapping control for Pan (relative)
UVCIOC_CTRL_MAP - Error: Inappropriate ioctl for device
mapping control for Tilt (relative)
mapping control for Pan Reset
mapping control for Tilt Reset
mapping control for Pan/tilt Reset
mapping control for Focus (absolute)
mapping control for LED1 Mode
mapping control for LED1 Frequency
mapping control for Disable video processing
mapping control for Raw bits per pixel
o: www-folder-path…: ./www/
o: HTTP TCP port…: 8090
o: username:password.: disabled
o: commands…: enabled
The only modification I made was to the port that the server runs on where I changed it from 8080 to 8090.
Thank you!
