Ok so fresh board.
plugged it in, and let windows search for the drivers. Nothing. Manual check for updates → Nothing. So apparently g_multi unlike g_serial, or g_ether is not detected by windows during a manual update.
Then going to BBB-drive\Drivers\Windows\ I copied the bone_D64.exe driver to my desktop. Then executed the drivers installer. There are 4 popups that you must click on the “install” button. Afterwards, I reset the board by pressing the power button, which is farleft of the ethernet jack, with the ethernet jack pointed down. Once the board came back up. I opened puTTY, put in 192.168.7.2 for the IP, hit enter. username debian, password temppwd. Bam im in.
debian@beaglebone:~$ uname -a
Linux beaglebone 3.8.13-bone47 #1 SMP Fri Apr 11 01:36:09 UTC 2014 armv7l GNU/Linux
debian@beaglebone:~$ cat /boot/uboot/ID.txt
BeagleBoard.org BeagleBone Debian Image 2014-04-23
debian@beaglebone:~$ lsmod
Module Size Used by
binfmt_misc 5377 1
g_multi 47670 2
libcomposite 14299 1 g_multi
mt7601Usta 601404 0
There is also a g_serial part of g_multi . . .
Debian GNU/Linux 7 beaglebone ttyGS0
default username:password is [debian:temppwd]
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
The IP Address for usb0 is: 192.168.7.2
beaglebone login: debian
Password:
Last login: Wed Apr 23 22:21:04 UTC 2014 from 192.168.7.1 on pts/0
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
You just need to know the COM port the BBB presented its self as, change the baud rate to 115200, and turn hardware control to none, in puTTY.
