I’ve got a BBB in less then three days, and I found I cannot login through the SSH panel.
Login through a usb2ttl cable is ok, but everytime I try the SSH, the connection will not establish both on Windows 7 32-bit and Ubuntu.
I follow the instruction on the website:
http://beagleboard.org/Getting%20Started
After I plug in the usb cable, and run ipconfig on ubuntu terminal, the output will be:
steve@steve-Inspiron-M4010:~/Downloads$ ifconfig
eth0 Link encap:Ethernet HWaddr f0:4d:a2:c8:c9:53
inet6 addr: fe80::f24d:a2ff:fec8:c953/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:14 errors:0 dropped:16 overruns:16 frame:16
TX packets:50 errors:0 dropped:0 overruns:0 carrier:4
collisions:0 txqueuelen:1000
RX bytes:5610 (5.6 KB) TX bytes:10823 (10.8 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:4984 errors:0 dropped:0 overruns:0 frame:0
TX packets:4984 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:595411 (595.4 KB) TX bytes:595411 (595.4 KB)
wlan0 Link encap:Ethernet HWaddr 1c:65:9d:e3:45:28
inet addr:180.160.8.128 Bcast:180.160.8.255 Mask:255.255.255.0
inet6 addr: fe80::1e65:9dff:fee3:4528/64 Scope:Link
RX packets:64211 errors:0 dropped:0 overruns:0 frame:0
TX packets:70712 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:68315915 (68.3 MB) TX bytes:10045511 (10.0 MB)
No ip addr like the 192.168.7.2 said in the instruction.
So will any of you give a proper solution on this?
