Srinivas,
Check to make sure the pins are muxed correctly I had the same issue yesterday using the 3.8 kernel, and it turned out the default pinmux settings did not bring out the GPIO pins.
-c
Srinivas,
-c
Hi Chris,
You are right.
As explained in below link
I modified the “arch/arm/mach-omap2/board-am335xevm.c” file as below and compiled the kernel.
213 static struct omap_board_mux board_mux[] __initdata = {
214
215 // New line added by me.
216 AM33XX_MUX(GPMC_AD6, OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT),
217
218 AM33XX_MUX(I2C0_SDA, OMAP_MUX_MODE0 | AM33XX_SLEWCTRL_SLOW | AM33XX_INPUT_EN | AM33XX_PIN_OUTPUT),
219
220 AM33XX_MUX(I2C0_SCL, OMAP_MUX_MODE0 | AM33XX_SLEWCTRL_SLOW | AM33XX_INPUT_EN | AM33XX_PIN_OUTPUT),
221
222 { .reg_offset = OMAP_MUX_TERMINATOR },
223 };
Now my commands are working fine. Thanks a lot.
Regards
Srinivas
