Hi, I am using a beagle bone green wireless and recently flashed it with AM335x Debian 11.7 2023-08-05 4GB eMMC IoT Flasher Debian image for BeagleBone Black Kernel: 5.10.168-ti-r68 U-Boot: v2022.04. I want to use pins P8.11,12,14,15,16 in python as GPIO inputs for a project but am running into this error with this simple code. On a fresh BBGW I am running Debian 8 and can use the pins with no error.
import Adafruit_BBIO.GPIO as GPIO
pin = “P8_11”
GPIO.setup(pin, GPIO.IN)
print(f"{pin} pass")
debian@BeagleBone:~$ sudo python goviTesting/gpio_test.py
Traceback (most recent call last):
File “/home/debian/goviTesting/gpio_test.py”, line 7, in
ValueError: Set gpio mode failed, missing file or invalid permissions.
Here is an output of of /boot/uEnv.txt and sudo beagle-version
debian@BeagleBone:~$ cat /boot/uEnv.txt
#Docs: Making sure you're not a bot!
uname_r=5.10.168-ti-r68
#uuid=
#dtb=
###U-Boot Overlays###
###Documentation: Making sure you're not a bot!
###Master Enable
enable_uboot_overlays=1
###Overide capes with eeprom
#uboot_overlay_addr0=.dtbo
#uboot_overlay_addr1=.dtbo
#uboot_overlay_addr2=.dtbo
#uboot_overlay_addr3=.dtbo
###Additional custom capes
#uboot_overlay_addr4=.dtbo
#uboot_overlay_addr5=.dtbo
#uboot_overlay_addr6=.dtbo
#uboot_overlay_addr7=.dtbo
###Custom Cape
#dtb_overlay=.dtbo
###Disable auto loading of virtual capes (emmc/video/wireless/adc)
#disable_uboot_overlay_emmc=1
#disable_uboot_overlay_video=1
#disable_uboot_overlay_audio=1
#disable_uboot_overlay_wireless=1
#disable_uboot_overlay_adc=1
##cape Universal Enable
enable_uboot_cape_universal=1
###Debug: disable uboot autoload of Cape
#disable_uboot_overlay_addr0=1
#disable_uboot_overlay_addr1=1
#disable_uboot_overlay_addr2=1
#disable_uboot_overlay_addr3=1
###U-Boot fdt tweaks… (60000 = 384KB)
#uboot_fdt_buffer=0x60000
console=ttyS0,115200n8
cmdline=coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet
#In the event of edid real failures, uncomment this next line:
#cmdline=coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet video=HDMI-A-1:1024x768@60e
#Use an overlayfs on top of a read-only root filesystem:
#cmdline=coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet overlayroot=tmpfs
##enable Generic eMMC Flasher:
#cmdline=init=/usr/sbin/init-beagle-flasher
sudo beagle-version
eeprom:[A335BNLTGW1ABBGW22110272]
model:[TI_AM335x_BeagleBone_Green_Wireless]
dogtag:[BeagleBoard.org Debian Bullseye IoT Image 2023-08-05]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot SPL 2022.04-ge0d31da5 (Aug 04 2023 - 18:48:26 +0000)]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-bonegreen-wireless-uboot-univ.dts]
UBOOT: Loaded Overlay:[BB-ADC-00A0.kernel]
UBOOT: Loaded Overlay:[BB-BBGW-WL1835-00A0.kernel]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0.kernel]
UBOOT: Loaded Overlay:[wl1835_bt]
kernel:[5.10.168-ti-r68]
nodejs:[v12.22.12]
/boot/uEnv.txt Settings:
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-cape-overlays]:[4.14.20210821.0-0~bullseye+20210821]
pkg:[bb-customizations]:[1.20230720.1-0~bullseye+20230720]
pkg:[bb-usb-gadgets]:[1.20230414.0-0~bullseye+20230414]
pkg:[bb-wl18xx-firmware]:[1.20230414.0-0~bullseye+20230414]
pkg:[kmod]:[28-1]
WARNING:pkg:[librobotcontrol]:[NOT_INSTALLED]
pkg:[firmware-ti-connectivity]:[20210315-3]
groups:[debian : debian root adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal input render bluetooth netdev i2c gpio admin tisdk weston-launch cloud9ide]
cmdline:[console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 41.071036] remoteproc remoteproc0: powering up wkup_m3
[ 41.071075] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 41.071377] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 66.085819] remoteproc remoteproc1: 4a334000.pru is available
[ 66.123905] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
[ 800.293368] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 800.299915] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 800.713252] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 800.919482] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 800.933555] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 800.977292] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 800.992326] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 800.995095] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.020992] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.039749] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.046644] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.060760] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.072800] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.080798] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.108759] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.120662] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.128462] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.141392] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.152683] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.161731] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
[ 801.172713] Modules linked in: aes_arm_bs crypto_simd cryptd ccm wl18xx wlcore mac80211 cfg80211 pru_rproc irq_pruss_intc libarc4 pm33xx pruss pvrsrvkm(O) ti_eqep counter c_can_platform c_can can_dev wlcore_sdio evdev wkup_m3_ipc uio_pdrv_genirq uio cpufreq_dt ip_tables x_tables spidev
dmesg | grep pinctrl-single
dmesg | grep gpio-of-helper
dmesg | grep wlcore
[ 67.567989] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 67.580507] wlcore: WARNING Detected unconfigured mac address in nvs, derive from fuse instead.
[ 67.580531] wlcore: WARNING This default nvs file can be removed from the file system
[ 67.611572] wlcore: loaded
[ 68.751821] wlcore: PHY firmware version: Rev 8.2.0.0.243
[ 68.827695] wlcore: firmware booted (Rev 8.9.0.0.83)
[ 70.118324] wlcore: Association completed.
[ 800.293359] WARNING: CPU: 0 PID: 1156 at drivers/net/wireless/ti/wlcore/sdio.c:78 wl12xx_sdio_raw_read+0x14c/0x1b4 [wlcore_sdio]
[ 800.293662] [] (warn_slowpath_fmt) from [] (wl12xx_sdio_raw_read+0x14c/0x1b4 [wlcore_sdio])
[ 800.293781] [] (wl12xx_sdio_raw_read [wlcore_sdio]) from [] (wlcore_irq_locked+0xcc/0x7b4 [wlcore])
[ 800.293863] [] (wlcore_irq_locked [wlcore]) from [] (wlcore_irq+0x5c/0x1c8 [wlcore])
[ 800.293908] [] (wlcore_irq [wlcore]) from [] (irq_thread_fn+0x1c/0x7c)
[ 800.299906] WARNING: CPU: 0 PID: 1156 at drivers/net/wireless/ti/wlcore/main.c:803 wl12xx_queue_recovery_work.part.0+0x50/0x54 [wlcore]
[ 800.300215] [] (warn_slowpath_fmt) from [] (wl12xx_queue_recovery_work.part.0+0x50/0x54 [wlcore])
[ 800.300286] [] (wl12xx_queue_recovery_work.part.0 [wlcore]) from [] (wlcore_irq+0x164/0x1c8 [wlcore])
[ 800.300329] [] (wlcore_irq [wlcore]) from [] (irq_thread_fn+0x1c/0x7c)
[ 800.304264] wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.83
[ 800.304300] wlcore: down
[ 800.304350] wlcore: down
[ 800.713244] WARNING: CPU: 0 PID: 136 at drivers/net/wireless/ti/wlcore/sdio.c:123 wl12xx_sdio_raw_write+0x194/0x1bc [wlcore_sdio]
[ 800.713903] [] (warn_slowpath_fmt) from [] (wl12xx_sdio_raw_write+0x194/0x1bc [wlcore_sdio])
[ 800.714016] [] (wl12xx_sdio_raw_write [wlcore_sdio]) from [] (wlcore_set_partition+0xd8/0x520 [wlcore])
[ 800.714088] [] (wlcore_set_partition [wlcore]) from [] (wl12xx_set_power_on+0x6c/0x144 [wlcore])
[ 800.714155] [] (wl12xx_set_power_on [wlcore]) from [] (wl12xx_chip_wakeup+0x24/0x23c [wlcore])
[ 800.714223] [] (wl12xx_chip_wakeup [wlcore]) from [] (wl1271_op_add_interface+0x67c/0xb04 [wlcore])
[ 800.714366] [] (wl1271_op_add_interface [wlcore]) from [] (drv_add_interface+0x38/0x1d4 [mac80211])
[ 800.908051] wlcore: ERROR firmware boot failed despite 3 retries
lsusb
Bus 001 Device 002: ID 0424:2514 Microchip Technology, Inc. (formerly SMSC) USB 2.0 Hub
END
Please let me know if you need anymore information.
