hi *,
I am slowly coming to understand the openembedded/bitbake built
process. I still have some configuration questions:
Let's assume that I wanted to build a distribution which matches the package:
http://www.angstrom-distribution.org/repo/?pkgname=kernel-3.2.9%2B
which is displayed as
kernel-3.2.9+ 3.2-r5a+gitr09e9651bcf2ee8d86685f2a8075bc6557b1d3b91
Am I right to assume that in the end this package is build from the
sources which can be found in the corresponding branch of
https://github.com/koenkooi/linux/tree/linux-ti33x-psp-3.2-r5a+gitr09e9651bcf2ee8d86685f2a8075bc6557b1d3b91
And if I run bitbake virtual/kernel which will AFAIK built exactly
such a kernel image - how can I make sure in my build/conf/local.conf
that I would like to have this version of the kernel?
I just have a DISTRO variable set to DISTRO = "angstrom-2010.x"
I do not understand yet, how to configure the build system, so that I
end up with builds which are essentially a replication of "official"
releases of the angstrom beaglebone distribution.
How can I query the build system which versions it nows about? Do I
need to change the branch of the openembedded directory? Do I need to
set DISTRO or DISTRO_VERSION variables? Can I query which distros and
version the build system knows about, aka what would constitute legal
values?
Thanks for your help,
Markus
hi *,
No, it builds it from the recipe in meta-ti which does *NOT* use that git tree. The above git tree can be described as "for people too lazy to apply patches".
Those are built by following the instructions at http://www.angstrom-distribution.org/building-angstrom
bitbake -s
regards,
Koen
D'oh. Next try:
So it is essentially pulling the sources from the arago github and
applying all the patches because eventually I end up in this recipe:
https://github.com/Angstrom-distribution/meta-ti/blob/master/recipes-kernel/linux/linux-ti33x-psp_3.2.bb
Markus
Correct. Managing patches is a lot easier when you're not upstream, just like Greg KH is managing his linux-stable tree: http://git.kernel.org/?p=linux/kernel/git/stable/stable-queue.git;a=tree;f=queue-3.2;h=3935bb6ea3f680780de4b4aaf3bc0073b2196ffb;hb=HEAD
regards,
Koen
