A couple of us have finished a draft of an initial ubuntu install
guide for the beagleboard, located here: ( http://elinux.org/BeagleBoardUbuntu
) Eventually this will probably be located on ubuntu's wiki..
Ubuntu 9.04 for arm is still in an early alpha stages, but is
performing quite well. I've replaced a couple internal mojo-handhelds
projects with ubuntu builds. Note, for those looking for a very fast
desktop, many packages are still only built for "armv5" (Angstrom is
built for armv7)... Currently Ubuntu developers are still looking
into creating optimized libraries..
Native kernel's are currently being built on the same beagleboard that
is building mojo & debian kernel deb's. (all in unique distro chroots
of course) : http://www.rcn-ee.com/deb/kernel/beagle/jaunty/
Compared with mojo & debian, these directions have been revised to be
as simple and straightforward for new users. ( Oliver's root file
system build script helps out a lot! )
guide for the beagleboard, located here: ( BeagleBoardUbuntu - eLinux.org
Can you update the BeagleBone Black Project Spotlight: Shield I/O - BeagleBoard links as well?
Should I give it a "Top Project" entry on the home page?
Hi Jason,
Can do!.
I'm thinking it might be a good idea to replace the 'mojo-handhelds'
project listed there with the 'ubuntu' project.
Reasons:
Mojo-Handhelds, Project status/future is still unknown, hasty is
starting to suffer from bitrot. Andrew (nokia) should have an update
sometime this march.
Ubuntu: Sponsored by Canocial/ARM, lots of dev's, and very active...
