I’m in the process of updating BoneScript to use the GPIO pins and the red and green LEDs on the Blue[1].
The are two gpio connectors, GP0 and GP1, so I’m labeling the pins
GP0_3, GP0_4, GP0_5 and GP0_6. This is because the first two pins on each connector is ground and 3.3V, so the 3rd pin is the first GPIO pin.
I also have GP1_3 and GP1_4. GP1_5 is the RED_LED and GP1_6 is the GREEN_LED, so I don’t define them.
So far I have the Red and Green LEDs working. I just had to adjust for the different path in /sys/class/leds
The GPIO pins are a bigger challenge.
GP0_4 and GP0_6 map to P9_23 and P9_28 respectively, making them easy to do.
The rest are tricky to do since none of them have a pinmux in /sys/devices/platform/ocp and BoneScript wants to be sure the pinmux is set correctly.
My hackaround is check for a pinmux and if not found, ignore the mux and hope it’s set correctly.
What’ the correct why to do this? That is, how do I set the pinmuxes for gpios 57, 116, 98, and 97?
I have a second problem that comes from running as debian, not root. Let’s say we are setting the pinMode for GP0_3 which is gpio 57,
bonescript checks /sys/class/gpio to see if gpio57/value is there, if not it writes 57 to /sys/class/gpio/export and gpio57 appears.
This works fine.
Next it writes “out” to gpio57/direction. This fails because of write permissions. But it you rerun the BoneScript it succeeds. It appears to be a timing problem. BoneScript is writing to the file before the OS can set the permissions so debian to write to it.
How do we fix this?
Thanks…
–Mark
[1] GitHub - MarkAYoder/bonescript: Scripting tools for the BeagleBoard and BeagleBone
