On bootup, my BBB comes up with an always wrong date/time. Since it has not battery, I understand this.
So, I want the BBB to query NTP to get the correct date on bootup. I am also running wireless, so it has to happen after the wireless connects. I am confused on how to accomplish this with the current Debian and systemd. Previous instructions say to just install ntp. But this doesn’t appear to do anything. I do see timedated and time-sync, but I am unsure if those are what I want or how to configure them.
If I run ntpdate manually, it works fine. I also see that cron.daily is also set to run ntpdate. In the syslog, I also see two calls to set system time from two different IP addresses. Those times are off by years. If I run ntpdate against those IP addresses, it runs fine.
Other documentation talks about ntpdate.service or timedatectl (coming in Jessie?), but that doesn’t exist here.
I also tried setting /etc/adjtime to LOCAL instead of UTC. I do actually want local time. I also linked /etc/localtime to /use/share/…/America/Los_Angeles.
Mostly I am just trying to figure out how to get started here. I am unfortunately rather unfamiliar with systemd. Thanks.
