On Mon, 6 Jan 2020 06:57:32 -0500, Michael Ascenzi
<mascenzi80-Re5JQEeQqe8AvxtiuMwx3w@public.gmane.org> declaimed the
following:
What is not clear to me is the use of the scripts used to configure USB0.
/boot/uboot/scripts/setup-ubuntu-armhf-3.8.13-bone30.sh makes changes at
bootup to configure for the static IP that is used on USB0. I'm not sure
how I would modify it for my needs. Or if there are other things I need to
worry about.
Since your original post mentions the plan to use a USB<>Ethernet NIC
adapter... I'm presuming you have the USB host port available (I don't
think the client/power port has OTG capability to drive any such adapter)
... Just leave the existing USB network alone -- that's an RNDIS style USB
gadget. The USB<>Ethernet NIC should have its own driver and probably
appears as a different ETH# device. Likely it will even attempt DHCP
negotiation when connected to a live network.
I'd probably just connect that USB<>Ethernet NIC, hook to a local
router/switch, and see what shows up on the network. If the BBB shows up on
the router, SSH to the assigned IP and check the network names and
configuration for it.
Just tried an experiment with an old SIIG USB<>Ethernet NIC. Connected
to a regular BBB, moved my CAT-5 from the on-board Ethernet port to the
SIIG, and booted.
debian@beaglebone:~$ ifconfig
eth0: flags=-28669<UP,BROADCAST,MULTICAST,DYNAMIC> mtu 1500
ether d0:39:72:18:3e:e5 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 55
eth1: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 192.168.1.92 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::250:b6ff:fe5c:9084 prefixlen 64 scopeid 0x20<link>
inet6 2600:1700:e630:890::47 prefixlen 64 scopeid 0x0<global>
inet6 2600:1700:e630:890:250:b6ff:fe5c:9084 prefixlen 64 scopeid
0x0<global>
ether 00:50:b6:5c:90:84 txqueuelen 1000 (Ethernet)
RX packets 100 bytes 10874 (10.6 KiB)
TX packets 150 bytes 25270 (24.6 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 320 bytes 23680 (23.1 KiB)
TX packets 320 bytes 23680 (23.1 KiB)
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.7.2 netmask 255.255.255.252 broadcast 192.168.7.3
inet6 fe80::d239:72ff:fe18:3ee7 prefixlen 64 scopeid 0x20<link>
ether d0:39:72:18:3e:e7 txqueuelen 1000 (Ethernet)
RX packets 237 bytes 37904 (37.0 KiB)
RX errors 0 dropped 4 overruns 0 frame 0
TX packets 45 bytes 10460 (10.2 KiB)
usb1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.6.2 netmask 255.255.255.252 broadcast 192.168.6.3
ether d0:39:72:18:3e:ea txqueuelen 1000 (Ethernet)
Board has network connectivity over the SIIG unit (USB0 is showing only
since that is how I powered the BBB). Removing the SIIG and plugging into
the on-board Ethernet (and waiting while PuTTY times out a few times)
produced
eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 192.168.1.69 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 2600:1700:e630:890:d239:72ff:fe18:3ee5 prefixlen 64 scopeid
0x0<global>
inet6 fe80::d239:72ff:fe18:3ee5 prefixlen 64 scopeid 0x20<link>
RX packets 399 bytes 33810 (33.0 KiB)
TX packets 147 bytes 22696 (22.1 KiB)
device interrupt 55
RX packets 505 bytes 65150 (63.6 KiB)
TX packets 83 bytes 18187 (17.7 KiB)
