Urgently needed the image (.img or.xyz) of "Linux beaglebone 4.19.94-ti-r42 #1buster "
After updated my debian OS from 4.19.94-ti-r42 to 5.10.168-ti-r71, I have face some serious issues with my services. Now I cant work with the 5.10.168-ti-r71.
So Plz provided the .img or .xyz of the file 4.19.94-ti-r42
Thanks for your help, but after I flash the OS “Linux beaglebone 4.19.94-ti-r74 #1buster” to my eMMC my disk space is almost full /dev/mmcblk1p1 3.5G 3.3G 21M 100% /
It was found that folder usr uses
2.4G
debian@beaglebone:/usr$ sudo ls | xargs du -hs
112M bin
4.0K games
31M include
1.3G lib
30M local
7.0M sbin
921M share
4.0K src
debian@beaglebone:/usr$ cd /lib/
debian@beaglebone:/lib$ sudo ls | xargs du -hs
13M arm-linux-gnueabihf
12K console-setup
0 cpp
48K crda
108K cryptsetup
137M firmware
16K ifupdown
16K init
56K klibc-PupSAGgtpafMlSLXOLgje1kXFo8.so
0 ld-linux-armhf.so.3
32K lsb
16K modprobe.d
55M modules
6.5M systemd
216K terminfo
17M udev
So in /usr/lib while summing all file sizes listes it doesnot reaches 1.3G ?
Thanks for your reply
This is the image I used for flashing “bone-debian-10.13-lxqt-armhf-2023-07-01-4gb.img”
Pls tell whether there are clean flash and dirty flash (?); that causing the existing files prior to flashing continue in eMMc
Plz guide if I am wrong.
